VERY CONFUSED 95 GMC 6.5 TURBO DIESEL
Old Aug 27, 2012 | 03:54 PM
diffrangle's Avatar
Default VERY CONFUSED 95 GMC 6.5 TURBO DIESEL
hey guys,
anyone know if a 95 gmc 6.5 turbo diesel has a ecm? and if so where is it located?
every time one of these codes pop up. it shuts of the egr solenoids.
now can the ecm be bad or the chip inside ecm be bad?or am i looking up the wrong area for these codes to be popping up?
found the ecm in behind glove box.dont know how to get out .another question.took egr out .now i tried creating vacumme by sucking on it.should that plunger move freely? I know its spring loaded,i dont get any movement on it until i press on it then the vacumme works a little.
there is a fairly new vac pump on the truck.But they are known to go.It does have vac.I just dont have a guage to read vac pressure.and I know pretty much with these three codes its all vac related or electrical trying to figure out what path to go.
well broke down got a vac gauge.reading about 20 to 22 it bounces around a bit.now some how on the way home got a 29 code glow plug relay circuit fault .im about ready to beat this truck with a sledge patiance is wearing thin.i was told to use test light wire on pos of battery and put on the glow plug terminal should light up if good.well they are fine .if this is the rite way .also when turn key on normally you will hear a click along with buzzer.i usually wait for buzzer to stop and then i start it. there is no click after a few seconds .it will start but engine still warm.IS THERE A RELAY AND WHERE IS IT LOCATED?
Old Aug 27, 2012 | 04:39 PM
Mayhem's Avatar
You say you are getting codes what are they it would help to know what they are
Old Aug 27, 2012 | 05:09 PM
diffrangle's Avatar
started out with code 33 egr control pressure/baro sensor circuit high (low vac) checked all vac lines no leaks.then code 32 exhaust gas recirclution (EGR) curcuit and code 78 wastegatesolenoid fault
now code 29 glow plug relay circuit fault and code 44 egr pulse width error
oh and glow plugs still not responding.and unable to reset codes .how do you test a glow plug relay?
Last edited by diffrangle; Aug 27, 2012 at 05:15 PM. Reason: Automerged Doublepost
Old Aug 27, 2012 | 05:41 PM
Mayhem's Avatar
Is the WTS coming on at all??if not then it's probally bad,have you disconnected the batteries for 10 minutes yet? that will reset
Old Aug 27, 2012 | 05:46 PM
diffrangle's Avatar
sorry dont know all abbreveations what is WTS? yes i disconnected batteries for about 15- 20 min
Old Aug 27, 2012 | 05:49 PM
Mayhem's Avatar
WTS=wait to start,you staill have those code safter disconecting batteries<meaning both batteries????
Old Aug 27, 2012 | 06:03 PM
diffrangle's Avatar
YES,the buzzer does work .but i was always able to hear the glow plug relay click during the WTS.AND YES BOTH BATTERIES.
i am code 44 now
a little recap on what i have done over the weekend.might help a little
Hello everyone,
I have had this truck for 12 yrs all stock 240,000 miles.Spent lots of cash$$$$ and a lot of busted knuckles to keep it running.
Anyway, the truck is spitting sputtering sometimes stalls mainly rite after starting up.
i suspect it being a fuel delivery problem.It does have an after market remote PMD w/heatsink on my third one figured try after market with a heatsink this time. Its about a couple years old.
IP has been replaced twice.maybe 4 yrs old. vacumme pump about 1yr old
i am trying to test the LP .had the truck running opened the pit **** no fuel came out then stalled. same with opening top of fuel filter canister.the only time i can get fuel out of these is when i am cranking the motor over. So now i get truck running again I check the voltage on the plug for the LP and only get 6 or 7 volts .My question is it should be 12 volts right? would the oil pressure switch play a part in this? Any ideas what else to check ? How about the fuel relay switch?
thanks again for anyone with the answer
well, ran a few tests this morning.i tested wires on oil pressure switch.with key on orange wire
12v ,tan wire 7-8v lime green 0v.Now ran a splice from lime green wire with truck running
got a 7-8v reading .now went back to LP there is black wire i'm sure this must be ground and a lime green wire for power now is reading 14v what a differance from last nights reading 7-8v. I didnt think last night to check oil pressure so no reading on that. too pisted-off by then.Now also tested the fuel pump relay,
0v -o o- 0v when key on ,7v- engine running
-o o- o- 0v
^ 0v
12v key on ,14v engine running
hope you understand diagram of relay.wish i would of checked this last night.
Today truck is running fine with the exception of
code 33 = egr control pressure/baro sensor circuit high (low vac) Once service light pops on loose a bit of power.I just put in nuetral and restart truck.then ok till i get on it again.
Any idea how to fix?
same thing going on with no fuel coming out of pitcock or filter when truck running ,only when cranking motor over.
ok? did some more wire testing and jumping tests.i ran a wire directly from battery to LP pump ran opened pitcock lots of fuel.
Next i tested the voltage on the wire that runs from the OPS to the pump, with plug not plugged into pump, key on 0v, 14v engine running. I hooked the plug back up to pump only reading 7-8v with motor running. And pump is not working.I still think that pump should kick on with key on.
next i tested the fuel pump relay again with unlpugged to fuel pump 14v .plugged in pump 7-8v
so i am going to purchase a oil pressure switch. If that aint it i will run a toggle switch. Screw it
problem was solved with replacing the oil pressure switch.so hopefully this will help someone down the road
Last edited by diffrangle; Aug 27, 2012 at 06:03 PM. Reason: Automerged Doublepost
Old Aug 27, 2012 | 06:05 PM
Mayhem's Avatar
I,m gonna say it is a bad EGR solinoid,has come unplugged, or the egr port is possibly being partially or completely blocked and I would say if the WTS light is not comming on the GP solinoid is bad or you have a bad fuse
Old Aug 27, 2012 | 06:10 PM
diffrangle's Avatar
is there a way to test the gp silonoid?checked fuse (its good)
any way computer playing games ?curiuos
i had the egr off and did notice one of the ports were pretty caked up .so i scraped it clean.
Last edited by diffrangle; Aug 27, 2012 at 06:13 PM. Reason: Automerged Doublepost
Old Aug 27, 2012 | 06:33 PM
Mayhem's Avatar
It is a million to one shot that the computer is bad so I would say no due to the fact truck will run bad ECM=non running truck,I am not sure about a test most ppl wj=hen having GP relay trouble do a relay mod some heavy gauge wire and a heavy duty push button starter switch will do the trick I put one on a 93 6.5 worked great for 2 years till the truck was sold if you go to your local NAPA ask for a STB6301 this is what I used on the last one I did
