any help here?
Old Aug 26, 2012 | 12:43 PM
Mike Carpenter's Avatar
Default any help here?
i have a 2000 f-350 with a 7.3 thats starts fine and runs fine after warm up. problem is for the first couple of miles it skips until the engine reaches normal operating temp. and ideas on this problem?
Old Aug 31, 2012 | 08:48 PM
cummin_un_glued's Avatar
FormerVendor
i would suggest a compression test since it gets better after the engine warms up. if the comp test comes out good then i would have the injectors tested.
