Which lift kit
Old Aug 25, 2012 | 07:39 PM
VAW's Avatar
VAW
Default Which lift kit
I want to put Nitto Dune Grapplers on my truck. My truck is a 94 Ford F350 Crew Cab how big of a lift kit do I need to put on it for 33 inch tires to fit? I need the lift kit to be as little as possible so I can still pull my gooseneck trailer.
Old Aug 30, 2012 | 04:20 PM
1AMatt's Avatar
Site Sponsor - 1aauto
You can probably run 33's without any lift
Old Aug 30, 2012 | 04:24 PM
VAW's Avatar
VAW
I'm not sure if I'm going with 33's that's the smallest I want to go with. It'll be between 33's and 37's.
Old Aug 30, 2012 | 04:35 PM
1AMatt's Avatar
Even 35's I have seen without any lift... They were stuffed in there but they fit okay. If you wanted 37's then you would need AT LEAST a 4" lift, preferably a 6"
Old Aug 30, 2012 | 04:39 PM
VAW's Avatar
VAW
Do you know how tall a truck would be with 37's and a 4 inch lift?
Bed height?
Old Aug 30, 2012 | 06:25 PM
1AMatt's Avatar
I don't know exactly how high, it would be massive though!
Old Aug 30, 2012 | 08:52 PM
tiremann9669's Avatar
In my book no lift is the best lift.
Old Sep 27, 2012 | 09:27 PM
Bigmark65's Avatar
For 37's i would go with 6in lift for sure. A leveling kit and you should be able to do 35's
Old Sep 28, 2012 | 11:58 AM
1AMatt's Avatar
Did you decide on a lift yet VAW?
Old Sep 28, 2012 | 02:54 PM
93_Fummins's Avatar
35's will fit just fine with no lift, although you may need to trim the bumper if it has started sagging as they will likely rub at full lock.
Also, as you mentioned towing, keep in mind that a bigger tire is going to change your towing experience unless you regear to match. My dad had a '92 F-350 CCLB 4x4 7.3IDIT with 3.73's and it turned into a dog towing when we put the 315's (35") on it. With the stock 265's it would tow the world just fine...
