Transmission cooler. a wee bit larger then stock!
Old Aug 25, 2012 | 04:10 PM
2004LB7's Avatar
Default Transmission cooler. a wee bit larger then stock!
so after patching a few transmission line leaks and springing another leak in the transmission cooler i thought it was time to replace them.
i lucked out a found one that was just the right size. if it was just 1/2 of an inch bigger then it wouldn't fit.
after running it for a week, i think i'll have to say: i like it.
on hot days of 100+ degrees in town driving the transmission temp gauge never gets above 150. in the morning when its around 70 out the gauge never moves up from cold. i am even seeing about a 20 degree drop in engine temps too at times.
so far i have not towed anything with it yet but have no reason to believe it will not keep up with the demand
anyways here are some photos
the cooler is 27 inches wide
and 18 inches tall
new hydraulic lines from mcmaster carr
Old Aug 25, 2012 | 05:05 PM
2500HeavyDuty's Avatar
good god almighty that thing is huge!!!
and those are some low *** temps too. during the summer drving through the city my trans will hit 200 sometimes. i also have a stage 4 too.
Old Aug 25, 2012 | 05:27 PM
2004LB7's Avatar
ya, my temps used to be around 200 all of the time. the best was about 180 on the freeway.
now is there such a thing as too cold? i wonder what winter will be like. might have to block some of it off
Old Aug 25, 2012 | 06:30 PM
block it off
i need to add a bigger one, and an external oil cooler to the front too
Old Aug 25, 2012 | 08:49 PM
Rick S's Avatar
What brand is it, or where did you get it? Looks good, I like it and want it
Old Aug 30, 2012 | 04:41 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Yea that thing looks awesome! Those temps are really good too
Old Aug 30, 2012 | 05:51 PM
2004LB7's Avatar
got mine on ebay for about $75
here is one that looks almost exactly like mine. same size too:
Setrab NASCAR road course 2 pass design aluminum oil cooler with AN-12 fittings | eBay
there are others that some of you adventurous one might get to work. just search ebay for "Nascar oil cooler"
the hydraulic hoses i got from McMaster Carr
McMaster-Carr
you will need some flair fittings. i removed the section of transmission line up to the nearest hard line and flared it to make the connection
good luck to who ever buys it first
play_dirty
Sep 9, 2015 09:33 AM
mabr0503
Feb 16, 2015 08:16 AM
mcompton1973
Feb 11, 2015 12:00 PM
BubbaDT55
Dec 7, 2014 08:52 AM
FlyingDutcman
Oct 28, 2014 04:56 PM
