07 5.9 cummins smokes and bad mileage
Old Aug 18, 2012 | 09:36 PM
John Hulsebosch's Avatar
Default 07 5.9 cummins smokes and bad mileage
I have replaced computer and injectors truck has no codes in it when Exceller rating truck has heavy black smoke and gets 10 miles to the gallon truck cranks good runs good cannot afford to drive any ideas on what the problem could be bought the truck used so somebody else could have been playing with it
Old Aug 18, 2012 | 09:41 PM
1999stroker's Avatar
Fuel filter been replaced? What's all done to truck? Does it have bigger tires? Auto or stick
Sent from my DROID BIONIC
Old Aug 18, 2012 | 09:46 PM
Fuel filter has been replaced tires are slightly oversize 32 1/2 inches tall don't know of anything else that's been done to the truck it is a four-wheel-drive 3500
Old Aug 18, 2012 | 09:49 PM
Dually? What about air filter? Is there a programmer on it?
Old Aug 18, 2012 | 09:55 PM
Dually yes filter yes and it is an automatic
Put program on and tookprogram off makes no difference
Last edited by John Hulsebosch; Aug 18, 2012 at 09:55 PM. Reason: Automerged Doublepost
Old Aug 18, 2012 | 10:06 PM
dangerous1965's Avatar
Sounds like a boost leak. Do you have gauges? Check all your boots and the intercooler!
Pressure test the system or just listen under load Power brake it safely!!
Old Aug 18, 2012 | 10:12 PM
No gauges. Truck runs good I have checked boots but not cooler
Old Aug 19, 2012 | 08:01 AM
Hummin Cummins's Avatar
What did you put on for injectors??
The first time I put injectors I didn't do the tq sequence right truck had low power high egts. I went back threw the injectors did everything over and truck runns perfect.
Old Aug 19, 2012 | 11:58 AM
Don't really know the dealership sold them. To me had old ones checked four were bad replaced all six
How do I do a commpresion check on a 06 5.9 with no glow plugs
Last edited by John Hulsebosch; Aug 19, 2012 at 11:58 AM. Reason: Automerged Doublepost
Old Aug 19, 2012 | 12:05 PM
RanchhandTCR's Avatar
through the injectors....
