1995 6.5 no glow plug light no start
Old Aug 15, 2012 | 06:45 PM
bad1972's Avatar
Default 1995 6.5 no glow plug light no start
Hi everyone I have a 1995 GMC 6.5 T! It started hard and missed sometomes , and one day it started but wouldnt do nothing but idol ,even if you held it on the floor .. Then it started n it would die !!! So I orderd a PMD and heat sync kit from SSDEISEL ! Installed it now WTS , antilock , service engine lights wont come on and wont start at all . any suggestions would be great !!!! Thanks
Old Aug 15, 2012 | 07:11 PM
Mayhem's Avatar
Check all the battery conections and engine grounds and have you pulled the codes yet?
Old Aug 15, 2012 | 07:32 PM
bad1972's Avatar
Thanks for your help its greatly appreciated !! I cleaned the ones back on trans dip stick bolt and it turns over great but i will clean the cables ! as far as codes SS said top right two pins in the connector is that correct ? The WTS light always worked till i installed the new PMD just has me puzzled ...
Old Aug 15, 2012 | 07:37 PM
Mayhem's Avatar
Yep short out the A and B terminals count all flashes
Old Aug 15, 2012 | 08:28 PM
bad1972's Avatar
I dnt have any pins in those spots mine is number 9-19 on that side is there another system ?
Old Aug 15, 2012 | 08:35 PM
Mayhem's Avatar
There is OBDII but its kinda trapizoid in shape is it posible its upside down???
Old Aug 15, 2012 | 08:50 PM
bad1972's Avatar
yea thats it is there way to run check on them?
Old Aug 15, 2012 | 08:55 PM
Mayhem's Avatar
just look at the pic upside down
Old Aug 15, 2012 | 09:06 PM
bad1972's Avatar
no i have OBDII trapazoid
Old Aug 15, 2012 | 09:13 PM
Mayhem's Avatar
oh you will need a scan tool of some sort to get the codes sorry about the misunderstanding there
