6.5 trans temp gauge
Old Aug 14, 2012 | 04:29 PM
duckslayer31's Avatar
Default 6.5 trans temp gauge
where do i hook up the sensor for the trans temp gauge on my 1999 6.5 turbo diesel with a 4l80e trans?
Old Aug 15, 2012 | 01:54 PM
cviola2005's Avatar
many people weld a bung into the oil pan during a fluid change.
quicker and easier, and also commonly done is using the out line to the cooler. use a proper tee fiiting and you will get instant results. measuring the temp of the oil thats actually doing the work
Old Aug 18, 2012 | 07:17 AM
ebarresi5894's Avatar
Yup or you can rig something up into the drain Plug for it as well
Old Aug 21, 2012 | 09:00 PM
NE2I's Avatar
quicker and easier, and also commonly done is using the out line to the cooler. use a proper tee fiiting and you will get instant results. measuring the temp of the oil thats actually doing the work[/QUOTE]
Which one is the out line?
Thanks
Old Aug 22, 2012 | 01:31 PM
cviola2005's Avatar
you can try using am infrared temperature gun and shoot it at both lines, whichever line is hotter is the one carrying fluid to the cooler. the cooler one would be the return
Old Sep 13, 2012 | 01:07 PM
CJ65's Avatar
Isn't there a test plug on the side of the trans that the sensor will screw into?
casper83
23
Jul 27, 2015 01:53 PM
JDurks2
16
Jun 7, 2015 08:57 PM
doodieroot
May 10, 2015 11:48 PM
apehangerjoe
Mar 26, 2015 03:01 AM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
