fuel issues on 6.5
Old Aug 10, 2012 | 03:18 PM
baker19's Avatar
Default fuel issues on 6.5
ok hopefully someone can help me. about 3 weeks ago my truck was having fuel issues (ie starting then stalling, hard starting, eratic throttle, hard acceleration and such) so i replaced my lift pump about 2 weeks ago. that solved the problem for about a week and then they came back. today i replaced my oil pressure senor and no i cant even get the truck to start itll turn over but it wont fire. https://www.dieselbombers.com/images/smilies/stars.gif
https://www.dieselbombers.com/images/smilies/dash2.gif
1993 gmc sierra
4x4 6in lift 35s
manual 5 speed
Old Aug 10, 2012 | 04:00 PM
Mayhem's Avatar
Do you have fuel at the injectors ??
Old Aug 10, 2012 | 04:51 PM
baker19's Avatar
i havent checked. i had the truck running after i threw the LP in no problem and now after i installed the ops it doesnt want to fire
Old Aug 10, 2012 | 05:05 PM
Mayhem's Avatar
Did you put a AC/DELCO OPS in the truck???cheap off brands suck spend the extra $ on genuine parts ans save time and $$$$$$$$$
Old Aug 10, 2012 | 05:26 PM
baker19's Avatar
Ok but it's a brand new sensor should it at least work?
Old Aug 10, 2012 | 05:30 PM
Mayhem's Avatar
About 3 months ago i replaced my CPS with a BWD brand it was crap tried 3 more before getting an AC CPS and now it starts and runs like a new truck and besides parts manufacturers make millions of parts each year and no one is perfect
Old Aug 10, 2012 | 06:26 PM
baker19's Avatar
Ok fair enough but I even put the old sensor back in and it still wasn't firing up
Old Aug 10, 2012 | 08:11 PM
Mayhem's Avatar
Ok try running a jumper wire from the positive terminal on one of your batteries to the G terminal on the ALDL port under the dash and crack open the T valve and see if fuel comes out if not you may have a bad LP
Old Aug 10, 2012 | 08:36 PM
baker19's Avatar
Thanks for the help so far I appreciate it!, but I believe I found the problem. I opened the tee valve and I had fuel all over the ground so there is a hole between the lp and the tee valve. Also the lp is 2 weeks old
Old Aug 10, 2012 | 08:45 PM
Mayhem's Avatar
Yep that will do it
