Axle Shaft Flange Gasket
Old Aug 10, 2012 | 10:59 AM
muzzfactor's Avatar
Default Axle Shaft Flange Gasket
Come to find out that none of the parts stores carry this gasket for my truck. Apparently it's a stealership only item. Unless you just want to go the "silcone" route. The part# is 5086767AC. My truck is a 2003 4x4 3500 SRW. I'm not sure if there is any variance from year to year. Hope this helps someone out.
Old Aug 13, 2012 | 01:54 PM
JDP3's Avatar
I found them at O'Reilly Auto Parts. They had to look the part number up in the reference books under AAM Axles. They did not list the part in their computer for the 3500. Part# Fel-Pro 12579. Bit late - hope it helps!
Old Aug 18, 2012 | 09:02 PM
hoot's Avatar
I had the same problem. Mine had a tear. Couldn't fins it listed so I just cleaned everything up real good and used some Oil type RTV
Old Aug 18, 2012 | 11:37 PM
tiremann9669's Avatar
I think most shops just use RTV.
caissiel
Sep 24, 2015 05:37 PM
JHALL30
Chevy/GMC Duramax 01-04 LB7
Sep 8, 2015 07:00 PM
Natenelson1
Jan 19, 2015 07:23 PM
Dec 19, 2014 02:30 PM
natenel1
Oct 26, 2014 03:09 AM
