had 3 codes now i have 10 help please
Old Aug 8, 2012 | 07:19 PM
slowcummins's Avatar
Default had 3 codes now i have 10 help please
3 first codes
P0073 Ambient Temperature Sensor High
P0107 Manifold Absolute Pressure Sensor Low
P0839 Four Wheel Drive (4WD) Switch Circuit High
sprayed the map and maf sensors with maf spray let dry and reconnected them did the key trick again to see if they went off and got these 10 codes
P0113 Intake Air / Charge Temperature Sensor High
P0112 Intake Air / Charge Temperature Sensor Low
P0340 Camshaft Position Sensor Circuit
P0237 Turbocharger Boost Pressure Sensor Low
P0193 Fuel Rail Pressure Sensor High
P0341 Camshaft Position Sensor Performance / Rationality
P0652 Sensor Reference Voltage 2 Circuit Low
P2508
this is the order the truck gave them to me thanks for any input
Old Aug 9, 2012 | 08:18 AM
dangerous1965's Avatar
Clean all your grounds and clear the codes see what returns!
Old Aug 10, 2012 | 10:44 PM
so i got my power pup in today and hooked it up cleared the codes never came back.so i drove it around for about 30 min had to something new on the truck got to try it out haha but got home did the key trick and got
P0602 Control Module Programming Error/NotProgrammed
but didnt get a cel for it though
Old Aug 21, 2012 | 10:12 AM
dmaxkiller's Avatar
i also got some codes... can somebody explain em to me.
p0646
p0480
my truck also throws p0236 and p0234. those might be the quadzilla though. my truck is throwing the BRAKE light and the ABS... also it keeps blowing out the fuse to my AC
longhorn12
6.7L Performance
Aug 29, 2015 01:28 PM
schwier94
Mar 8, 2015 06:09 PM
KimberlysTruck
Mar 5, 2015 06:28 PM
Renowest48
Dec 14, 2014 08:36 PM
Altonlee
9
Oct 8, 2014 02:31 PM
