put motor and trans out of 98 powerstroke in 99 superduty with v10
Old Aug 1, 2012 | 11:05 AM
Hartford59's Avatar
Default put motor and trans out of 98 powerstroke in 99 superduty with v10
I was just wondering if it was possible and the wiring had everything the motor is A-side.3 and the Trans is. A 5 speed
Old Aug 1, 2012 | 11:41 AM
CSIPSD's Avatar
As I said in your other thread, there is no 98 powerstroke. There are 97 OBS trucks and 99 Superduty trucks.
If its got a ZF5 then its an OBS truck.
Your looking at a ton of work, more then you understand.
Old Aug 1, 2012 | 11:44 AM
Hartford59's Avatar
Well its a 97 I guess but its a whole truck is cheap and I could pull the whole drive train and drop it in my truck. It comes as a complete truck.
Old Aug 1, 2012 | 11:59 AM
CSIPSD's Avatar
Doesn't matter. The floor hump will need to be changed, the 97 has small AA injectors, the ZF5 is not the tranny that comes in the superdutys so you will have issues there. You will need a diesel dash, the manual clutch peddle and power assembly out of a superduty. You will need to swap the vacuum system out of the motor and truck and install the power system.
Old Aug 1, 2012 | 12:04 PM
Hartford59's Avatar
I have the dash and floor the vacuum system won't bee hard. I had change t around on anther vehicle the clutch will he simple. I got all the parts. I cam make brackets I work in a dealership and have every tool in the world. I know it woo be tough but I have done sneak other crazy ****. I think it will take about60 hours total. And about a grand after I buy that other truck. I don't care if its pretty.
