PDA
View Full Version : Wanted To Buy (WTB) - Used
Pages : [1] 2 3 4
  1. Duramax Tow Mirrors
  2. Differential gears
  3. 67-69 C10 shortbed stepside
  4. <SPAN style="color:green;">Wanted: </SPAN>Wanted: Hub Cap for 2nd gen 3500
  5. power puck
  6. Wanted to buy some gauges
  7. Wanted 2007 Dodge 3500 dually spare wheel
  8. 12 Injectors
  9. wanted 22 or 26cm ht3b exhaust housing
  10. wanted 12cm super phat shaft exhaust housing
  11. Wanted 6bt/4bt Sae #3 flywheel manual trans
  12. hx40 14cm housing
  13. WTB or trade for 4:10 gears for dana 60's
  14. flywheel cover
  15. 2008-2010 Superduty Wheels
  16. Stock 16"x8" 2nd Gen Dodge 2500 Aluminum Wheels
  17. crank case breather used or new
  18. WTB: HE341Ve compressor backplate
  19. WTB VP44 core pump!
  20. Wanted Cummins flywheel housing
  21. one ton
  22. in need of a 5pd manual
  23. Stock Wheels
  24. 5.9 cummins
  25. 5" or 6" stack...
  26. WTT 24v 100hp Injectors for 50s
  27. twins/compound turbo setup
  28. 2000-2003 4x4 powerstroke truck or engine and trans
  29. turbo!
  30. NV4500
  31. 2001 dodge dually front center caps
  32. Need Truck hauled from devine,TX to florida to suncoast..
  33. need turbo bad
  34. 3rd gen aluminums
  35. HX 35 turbo
  36. NV5600 6spd trans and parts
  37. need fuel plates for cummins
  38. Parking brake cable(and a few other things)
  39. 241DHD transfer case
  40. 24v Throttle cable
  41. ht3b housing
  42. i need a good used vp44
  43. stock forged rods from a 12v or 24v cummins
  44. Inside Drivers Side door handle 1st Gen
  45. looking for
  46. Smarty with beta 4.2!
  47. Cummins T4 manifold and Misc.
  48. H1C turbo
  49. steering box
  50. Dodge Cummins transmission
  51. WTB D80 Rear end
  52. WTB AirDog Lift Pump
  53. WTB Aftermarket parts for 01 24v
  54. WHEELS
  55. 2wd 5speed for 6bt
  56. need an oil pan pick up tube fast!!
  57. 1998.5 Or Newer NV4500 Shifter Handle
  58. need ht3b 26cm housing
  59. Cummins 5.9 SAE#3 flywheel housing
  60. gearvendors
  61. 2004.5 3500 dodge owners manual!!!!
  62. overflow valve
  63. 1993 VW Eurovan MV Gas to Diesel conversion
  64. 1998-2001 TDI Golf or Jetta/Passat Wagon
  65. dodge 12valve cummins 4x4
  66. edge drag comp.
  67. Help I need a Motor Mount
  68. Rear Driveline for 02 Dodge quad SWB 4x4 6spd CTD
  69. WTB Good 4:10 gears sets for dana 60
  70. parts to finish 5 speed swap.
  71. need front end parts
  72. In need of some things! Please look!
  73. 12v Dodge
  74. WTB 1st Gen Auto w/OD good trans or rebuildable core NORCAL
  75. water outlet
  76. Stacks
  77. Pre 98 factory ford Alcoas
  78. Service Manual
  79. truck stacks
  80. Dodge diesel 727 trans.
  81. New motor centralized closing
  82. WTB cupholder - 01 cummins
  83. 5spd cummins tranny??????
  84. Turbo and injector pump
  85. Smarty Revo
  86. Need Spartan Programmer + Full straight-through exhaust
  87. WTB '06-'07 5.9 Laramie mega 4x4 dually
  88. Solid Single Wheel Bed for 1st gen Dodge
  89. looking for programmer?
  90. gauges
  91. Wanted 47rh
  92. HX35
  93. wtb gen2 12v 5spd 4x4 qc or cc
  94. need PARTS!!!!!
  95. chip
  96. WTB or WTT for a Cummins
  97. used chip
  98. stock 3rd gen cummins exhaust mnifold
  99. 4x4
  100. Looking for a nv4500 2wd trans...
  101. fender flares
  102. crankshaft
  103. WTB - 1st Generation Dodge
  104. need pyrometer wiring not the probe I have that
  105. stack tips!!!
  106. wtb: floor cup holder console for 94-02 dodge
  107. WTB Edge comp or Drag Comp?
  108. Wtb Baby H1
  109. wheels
  110. 3rd gen steel dually wheels
  111. wtb about 3 feet of 4 or 5 inch pipe
  112. Looking For tires in rims for 99 f 350
  113. tires
  114. need to buy front driveshaft
  115. Feeler for a first gen dodge parts truck need fenders pass door and maybe hood
  116. looking for a vacuum pump off of an 03 Dodge CTD...
  117. need a ford 6.0 diesel for an 04 f650
  118. WTB Edge Comp or Drag Comp.
  119. WTB Powersteering pump
  120. need a dpf
  121. 95-98 12V cummins
  122. WTB Drag Comp or a quadzilla product?
  123. need injector ford
  124. need a truck
  125. 12/or 24/block need
  126. Who's got 3rd Gen Wheels for sale
  127. Really need a rearend yoke for 96 dodge
  128. 10.25 REAR LOCKER and/or DANA 60 REAR Diff. NEEDED
  129. I need your broken/worn out fuel pump!
  130. Looking for a turbo timer.
  131. looking for cores Injectors, Delivery valves, Holders, VP44, Cp3
  132. 94-97 Fuel Tank module
  133. need at least a 6 inch stack any will do
  134. Need to buy some dodge parts
  135. 2.6 turbo
  136. Trubo Charger
  137. Engine wiring harness
  138. control arms
  139. 98 dodge tc
  140. needed: getrag 5 speed shift tower
  141. want 181 deliver valves for 94 cummins
  142. PARTS?!!
  143. WTB plow truck
  144. Ranger O\Drive
  145. 94-97 powerstroke
  146. P-Pump Swap Parts!
  147. Need a p7100 injection pump!!
  148. dually adapters?
  149. Need a 1st or 2nd gen fan idler pulley
  150. need 241 dhd t-case!!
  151. WTB 08 Ford 8 spoke, 8 lug wheel
  152. Anyone selling a nv4500 for 99 24v cummins 4x4?
  153. HOOD LATCH
  154. looking for used good chip?
  155. vp44
  156. CUMMINS box truck
  157. wanted--00-02 dodge DRW stuff
  158. HT3B 26cm housing
  159. Looking to buy a new Turbo
  160. anyone selling there DPF
  161. Need dana CAD ASAP
  162. turbo exhaust housings
  163. need a 90 degree pipe to do a single stack
  164. Wiring harness [cab]
  165. dana 80 rear
  166. output shaft
  167. 2nd gen parts
  168. 33x125.50-16.5 mud tires wanted
  169. need to buy a chip for my 98.5 cummins let me know what you got open to anything
  170. 98.5 cummins turbo needed
  171. Studs and sticks
  172. 3.55 or 3.73
  173. Cummins swap
  174. 1 gen grill
  175. VP44 NEEDED BAD
  176. 97' 2500 cummins fuel plate
  177. AAM 11.5 Axle
  178. In Need of Bed for 1st gen
  179. 99-02 Dodge Ram Cummins Gauge Cluster
  180. Spicer Black Plastic Hub Knob
  181. wanted, hx40 14 or 16 cm exhaust housing
  182. looking for a stack at least 6"
  183. 2wd dually springs...trade?
  184. need a set of 215 injectors
  185. Want Lb7 Programmer
  186. Weld Super single
  187. ATV tires
  188. '01 Headlights
  189. WTB: 4 In down pipe
  190. 2nd gen dodge intercooler boots needed
  191. WANTED - 275/65-20 TIRES
  192. 08 6.4L DPF Delete Tuner - CHEAP !!!
  193. cummins
  194. 215hp 12v cummins injectors
  195. 1995-2000 power stroke
  196. 7.3 programer
  197. spare 12v cummins
  198. wanted 33 12.50 16.5 tires
  199. 04.5 lly duramax injectors
  200. need lighter weight wheels on my dually
  201. wtb: hx40 turbo
  202. exhaust manifold 24v
  203. 33x12.50x16.5
  204. dodge ram cloth seats
  205. used vp44
  206. roll over truck or nv4500
  207. WTT 4BT
  208. FORD fuel heater
  209. Converter cores wanted
  210. Tips
  211. tips
  212. 17 inch chrome wheels trade for programer
  213. 22 or 24 dually wheels
  214. WTB Rims
  215. looking for edge comp/drag comp for 98.5- 2000
  216. 14 or 16 cm housing??
  217. WTB 47RH 4x4
  218. A-Pillar
  219. fuel injectors
  220. 6in stacks
  221. wanted ford
  222. in need of motor
  223. Overhead console
  224. 37x13.5R20's
  225. stacks
  226. Foglamp Bezzels
  227. stacks
  228. WTB Edge Comp or Drag Comp.
  229. injectors
  230. '01 Dodge Tow Mirrors
  231. LOOKING FOR A USED TURBO SETUP FOR MY 1990 7.3 EXTENDED CAB 5 SPEED MANUAL TRANS.
  232. edge Comp?
  233. hy35 wtb
  234. Looking to buy a nice Diesel truck
  235. WTB 12 valve cummins with auto tranny
  236. 92-97 F series hood bumpers & 2nd gen Dodge I/C
  237. 99 comp box
  238. 7 inch single stack tip
  239. 16inch alloy wheels
  240. need crankcase breather
  241. 1st gen injectors
  242. crankcase breather
  243. WTB 4" or larger lift kit for 2nd gen Dodge 3500
  244. "WANTED TO BUY" SECTION STRUCTURE - READ ME!
  245. Wtb Wastgated H1c
  246. p7100
  247. WTB fuel pressure Gauge
  248. WTB: HY35
  249. Pieces of bedliner...
  250. WTB: Front Wheel covers for Ford 85' dually
