Bigger tires
Old Jul 30, 2012 | 05:12 PM
codyawise's Avatar
Default Bigger tires
How big of tires can i put on my truck with it being at stock height? current tire size is 235/85/16. i'd like something taller and wider also. can anyone help?
Old Jul 30, 2012 | 05:27 PM
1999stroker's Avatar
I think I got 285/75/17 on mine ill have to double check thpugj
Sent from my DROID BIONIC
Old Jul 30, 2012 | 05:32 PM
codyawise's Avatar
any help would do
Old Jul 30, 2012 | 05:33 PM
baddodges's Avatar
I had a 99 with a 2 in leveling kit on the front. I ran 315s stock hieght 285 no prob.
Old Jul 30, 2012 | 05:48 PM
codyawise's Avatar
thanks
Old Jul 30, 2012 | 05:53 PM
RAW's Avatar
RAW
285/75R16 is about as big as you would want to go. You will be limited by the duals for width. If they rub together, your sidewall will fail very quickly.
Old Jul 30, 2012 | 06:02 PM
codyawise's Avatar
is there anyone to put some kind of spacer in between the two if the do rub?
also if i upsize to 285/75/16 will i need to get bigger rims?
Old Jul 30, 2012 | 06:26 PM
dolla_hite's Avatar
is your truck 2wd or 4x4? and yes they make spacers so they dont rub
Old Jul 30, 2012 | 06:36 PM
baddodges's Avatar
You can find spacers on ebay.id go with the 2 inch spacers.
Old Jul 31, 2012 | 12:05 PM
scottmorgan's Avatar
go to 2.5" Dodge Ram Leveling Kit - 1994-2012 - Hell Bent Steel and you can fit 35 easy. with my 2500 4x4 i could fit 35" tight but not rub. i put on the leveling kit and 3" body lift and have 37" tires without any issues.
