What i need for 4k GSK?
Old Jul 30, 2012 | 03:04 PM
12VALVECOUNTRYBOY's Avatar
Default What i need for 4k GSK?
I plan on ordering my 4k GSK next week, is all need 60lb valve springs or 110?? Ive been told differently. And also, where would yall recommend buying the kit from?
Thanks
Old Jul 30, 2012 | 04:04 PM
Farmboy 2.0's Avatar
Id look into doing the 60lbs valve springs as long as you dont plan on doing anything over 4000 rpm. If you worried id go with the bigger ones. But general rule of thumb is 60lbs for 4000 rpm.
Old Jul 30, 2012 | 04:15 PM
biged681985's Avatar
Ya 60lb is all thats needed for 4k
Old Jul 30, 2012 | 04:31 PM
Preciate it guys!
Old Jul 31, 2012 | 04:21 PM
Sudia247's Avatar
Would going with 110 Springs be a problem at all if you didn't have aftermarket tappets and Push Rods? And would they give trouble for a DD in the lower RPM Range?
Old Jul 31, 2012 | 06:13 PM
turbo2332's Avatar
i would say you would have more problem with the stock keepers pushing through with 110's at higher rpms befor bent pushrods???
Old Aug 3, 2012 | 12:56 AM
Sudia247's Avatar
So if you put in the titanium, aftermarket keepers and such, would the 110# function right on a daily driver still driving in lower RPM for majority of the time? Or would it struggle trying to open the valves at the lower RPMs for long duration?
Old Aug 3, 2012 | 07:07 PM
turbo2332's Avatar
they would work just fine. how many R's are you looking at turning. pretty large investment for almost not if you arnt over 4k. 60lbs springs and stock everything elso work fine with a 4gsk kit. the valve can pull through the stock keepers at high rpms and it would make matters worse if the spring tension was higher on top of that. all depends on what you need. the cam/pushrods/rockers open the valve. the springs return then to closed. generally higher tension springs will close the valve faster which is what is needed in the higher rpms so you dont float valves.
