WTB HX35 turbine housing T3 12cm
Old Jul 30, 2012 | 12:37 PM
clownmidget's Avatar
Default WTB HX35 turbine housing T3 12cm
Looking for a turbine (hot side) housing for a Holset HX35.
Needs to be twin scroll (divided) T3 mount.
Needs to be internally wastegated functioning properly. Don't need the exhaust plate, elbow, etc. just the actual turbine housing.
For reference here's the Holset numbers for the housing I need to replace:
3532214
01
E4
16 backwards E
Also, if it interests anyone, I have this exact housing already but the wastegate puck and wastegate arm hole are already welded shut for running an external wastegate/blowoff. Willing to trade or whatever -it's useless to me.
Thanks in advance.
Mike
Old Jul 30, 2012 | 01:09 PM
RAW's Avatar
RAW
I'm pretty sure I have a 12cm off my HX35 at home. It is fully functional, I removed it to install a 16cm housing. I'll look for it tonight, and send pictures if I find it.
Old Jul 30, 2012 | 02:39 PM
Many thanks! Hope it's the right one...
Old Jul 30, 2012 | 02:58 PM
RAW's Avatar
RAW
Should be, it's a standard HX35 12cm housing, that fits a stock application.
Old Jul 31, 2012 | 08:21 AM
Sounds good. The only tweak is my HX35 is a "G" - has the coolant and oil supplied center section. But that shouldn't matter
