Accidentally put mercon in 5r110........
Old Jul 29, 2012 | 11:37 AM
Links56's Avatar
Default Accidentally put mercon in 5r110........
Hello this is my first post on this forum. I have a 2003 F350 with a 12v cummins swap. I had a line pressure gauge on the transmission because I am still trying to fine tune the trans controller. Well the gauge busted some how and blew out most of my trans fluid the only thing I had with me was some old regular mercon/dextron 3 so I dumped it in to get me home. I know the trans has a thermostat but I am still Leary about getting all of the old contaminated fluid out. Is there some cheaper liquid that I can flush the old oil out with first? Its probably not possible to remove the thermostat temporarily? Any thoughts/ suggestions would be appreciated. Thanks in advance.
Old Jul 29, 2012 | 01:22 PM
Karls03's Avatar
How much did you put in? This is 17 quart system. To ensure that all of it is out, a complete trans flush is in order, I recommend a good transmission shop do that with the proper tools.
Mercon SP is a suitable fluid. I have found it at OReilly's for roughly $5/qt.
Old Jul 29, 2012 | 04:44 PM
Links56's Avatar
I put in about 6 quarts. I will flush it myself by preheating the oil as it goes in so the thermostat will stay open. I am just concerned if that flush will make it clean enough. I also don't know when all of the old fluid will be out of the system unless I could dye my trans fluid someway.
Old Jul 29, 2012 | 06:14 PM
HeavyAssault's Avatar
$250 at the dealer is cheap insurance that is done correctly.
Old Jul 29, 2012 | 10:03 PM
ntmdtr3fan's Avatar
had mine done (tranny flush) on my 07 f350 for about $120 a Pepboys. Watched them do it jsut to make sure they didnt screw up.
Old Jul 30, 2012 | 10:33 AM
Mdub707's Avatar
Mercon SP or Mercon LV are the only fluids that should be in there.
I'd take it to Ford for a full flush too. I highly doubt your thermostat even opened anyways, but better safe than sorry.
Old Jul 31, 2012 | 04:35 PM
driveway tech's Avatar
I vote ford flush. Not worth the risk.
Old Aug 1, 2012 | 07:48 PM
Links56's Avatar
I am taking it to ford in the morning, they quoted me a price of $129 to flush and change both filters. I asked the guy if he was sure and took down his name and all that good stuff. The last time I checked the filters were around 30-40 a piece and the oil from them was $8 a quart!!. Hopefully a few miles with the contaminated oil wont hurt anything. Thanks.
