Diesel Related Events Post All Diesel Related Event Information, Dates and Results Here - Includes Racing, Pulling, Dyno ect... All Local, State and National Event Information
*POST AND DISCUSS ALL DIESEL RELATED EVENTS HERE*
Attica Fair Pull, August 11th. Attica Ohio
Old Jul 29, 2012 | 09:56 AM
mdswartzmiller's Avatar
Default Attica Fair Pull, August 11th. Attica Ohio
ATTICA FAIR PULL, Attica Ohio
Saturday, August 11th - 6:00 P.M.
ATTICA FAIRGROUNDS
CLAY DIRT TRACK, INFIELD - 2 TRACKS
ANY QUESTIONS OR CONCERNS CONTACT GREG SWARTZMILLER 419-681-0173
Total Open Class Purse - $1500.00 each class
6500 LB OPEN TRACTOR AND TRUCK CLASS
-Tractor: cut tires permitted, 20" Hitch Height
-4WD Truck: DOT Tires, 26" Hitch Height
-2WD Truck: DOT Tires, 28" Hitch Height
8500 LB OPEN FARM - TRACTORS ONLY 20" HITCH HEIGHT
10000 LB OPEN FARM - TRACTORS ONLY 20" HITCH HEIGHT
SAFETY EQUIPMENT RECOMMENDED - ONE ENGINE ONLY
6500, 8500, 10000, 12000, 16000 MODIFIED FARM - TRACTORS 100% PAYBACK
STOCK APPEARING
P PUMP MAX - ALL TRACTORS
NO CUT TIRES
20" HITCH HEIGHT - ALL TRACTORS
3" TURBO INLET MAX
11000 LB STOCK - TRACTOR RULES 80% PAYBACK
7 MPH SPEED LIMIT - SLED REGULATED
20.8 TIRE SIZE
STOCK OR STOCK REPLACEMENT
STOCK APPEARING INJECTION PUMP
20" HITCH HEIGHT
ALL CLASSES: CLEVIS SIZE TO BE 3"x3.5" LONG OPENING ON TRACTORS AND TRUCKS
ALL CLASSES TRUCK RULES: Any questions contact Mike Swartzmiller 567-224-7945
FRONT WEIGHT RACK RCOMMENDED
ENTIRIES TO BE DETERMINED AT SCALES
4WD TRUCK GAS STOCK CLASSESS WITH LICENSE PLATES: 80% PAYBACK
6500 GAS STOCK CLASS - MUST BE STOCK APPEARING
RULES:
STREET LEGAL
FRONT BUMPER
NO LOCKED OR RIGGED SUSPENSIONS - BLOCKS WILL BE ALLOWED
NO OPEN HEADERS, INFRAME EXHAUST REQUIRED
NO NITROUS OXIDE
26" RIDGID HITCH HEIGHT BUMPER OR REESE STYLE
PUMP GAS
4WD TRUCK - 6500 ALTERED GAS - 100% PURSE PAYBACK
RULES:
26" HITCH HEIGHT
LADDER BARS
HEADERS/EXHAUST BEHIND CAB
NO WELDED SUSPENSION
MUST RUN DOT TIRES
4WD TRUCK - 6500 PRO STOCK GAS - $300.00 PLUS 100% PURSE PAYBACK
RULES:
26" HITCH HEIGHT
MUST RUN DOT TIRES
SUPER MODIFIED 4WD - OSTPA RULES - $2000.00 PAYOUT
MUST RUN DOT TIRES - ALL DIESEL TRUCK CLASSES
26" HITCH HEIGHT - ALL DIESEL TRUCK CLASSES
8000 LB WORK STOCK DIESEL 4WD TRUCK - $700.00 PURSE
STOCK APPEARING TURBO
8000 LB DIESEL 4WD TRUCK 2.6 TURBO INLET - $1500.00 PURSE
2.6 TURBO WILL BE CHECKED WITH 2.65 PLUG
8000 LB OPEN DIESEL 4WD TRUCK - $2000.00 PURSE
GENERAL RULES:
ALL VEHICLES MUST BE OPERATED SAFELY
NO ALCOHOLIC BEVERAGES CONSUMED BY ANYONE DIRECTLY CONNECTED WITH VEHICLES ENTERED IN THE PULLING CONTEST
ALL PULLS START WITH A TIGHT CHAIN
ANYTHING DEEMED UNSAFE BY OFFICIALS, DROPPED ON THE TACK IS GROUNDS FOR DISQUALIFICATION
ALL DECISIONS MADE BY THE OFFICIALS ARE FINAL!
TROPHIES FOR 1ST PLACE WINNERS
$20 ENTRY FEE
