blowing fuses
Old Jul 27, 2012 | 10:46 AM
06blackstroke_11's Avatar
Default blowing fuses
on my 06 6.0 ive got a western hauler rack on it with 4 bright *** led lights. it keeps blowing the 20amp fuse in the fuse box under the hood when i hook any trailer up to it an sometimes it blows out on its own at random times i have no idea why so help me out guys thanks
Old Jul 27, 2012 | 10:56 AM
Karls03's Avatar
Don't LEDs need a relay of some sort because of the power they draw? It sounds like the combination of the LED rack lights and a trailer are over loading the 20A fuse. Obviously check the grounds for the rack installation first, you may need to sand some paint off and make a bare metal connection.
Old Jul 27, 2012 | 11:05 AM
Well I bought it from a friend he has a 6.4 an he never had any problems with it. An the lights are plugged in to my 4 prong trailer plug at the back of the truck
Old Jul 27, 2012 | 11:13 AM
Karls03's Avatar
I had a trailer once and of the 5 of us that hooked up to it, the lights only worked right on 2 trucks, two of those three were Super Duties. If it was plugged into the same port on that 6.4 then you're about to be good friends with a multimeter. Sorry, I'm not much help on electrical issues.
Old Jul 27, 2012 | 01:35 PM
Mdub707's Avatar
LED's draw VERY LITTLE power.
To me it sounds like a bad ground somewhere or an open wire rubbing somewhere. I'm with karl, I hate electrical stuff.
Old Jul 27, 2012 | 03:23 PM
Yea I thought LEDs draw little power too but where could a ground be loose at. I'm no electrical guru that's why I pay someone to do my electrical work
Old Jul 27, 2012 | 03:45 PM
Karls03's Avatar
I don't remember if they were LEDs or what, but when these bright lights first came out, if you plugged a bulb into your blinker socket and it hit really fast you needed to add a relay or something to get the synch back. This was back in the 90s and I have drank HEAVILY since then.
Old Jul 27, 2012 | 04:03 PM
2500HeavyDuty's Avatar
it sounds like you have a short to ground somewhere. the fuse is blowing even when the trailer is not hooked up. all signs are pointing to a a short to ground.
Old Jul 30, 2012 | 09:47 AM
Mdub707's Avatar
Karl, you are correct. You couldn't just directly plug in the LED bulb into the standard socket, needed some sort of circuitry to make it work right. Not sure this is the case here though.
I hate electrical crap!
camp9
Mar 25, 2017 07:40 AM
mihilo
Sep 16, 2015 10:42 AM
david.burger
May 30, 2015 08:25 AM
Dak_summers
Jan 22, 2015 08:45 PM
cmalson
Nov 29, 2014 12:57 PM
