Painting valve cover tips
Old Jul 26, 2012 | 06:53 PM
1999stroker's Avatar
Default Painting valve cover tips
ok guys im going to do a little r&r on mu truck to make it look a little nicer. I want to paint the valve cover do I need to replace the gasket or no? And what do the bolts get torqued back to? And what fits that last bolt under the dash
Sent from my DROID BIONIC
Old Jul 26, 2012 | 07:44 PM
Red_Rattler's Avatar
High Tech Redneck
I would, 18ft lbs, ratchet wrench
Old Jul 26, 2012 | 07:46 PM
High Tech Redneck
Adjust the/ check the valves while your in there!
Old Jul 26, 2012 | 07:51 PM
Ok. How would I go about adjusting/ checking the valves? And can I just go to local part store for gasket?
Old Jul 26, 2012 | 09:15 PM
wyodiesel92's Avatar
According to cummins inspect the gasket for any damage and if its in good shape reuse. Cummins claims the gasket is made to be removed multiple times before replacement is neccesary. They designed it so multiple repairs and maintenance precedures coukd be done before having to replace. I just adjusted my valves about 2k ago and reused the gasket because it was in good shape and no leaks yet.
Old Jul 26, 2012 | 09:32 PM
dieseldude848's Avatar
the gasket is a very thick flexable rubber, just make sure you clean it good, and give it a light coating of oil for it to compress down and make a seal.
Old Jul 26, 2012 | 09:37 PM
High Tech Redneck
Tools needed :
A set of feeler gauges
Open end wrenches 9/16 in or a 14mm, 10mm
Allen key set
Socket set 10mm, a 7/8 in or 22mm
Torque wrench
Inspection mirror
Optional tools
Cummins barring tool P/N 3377371
Flashlight
Specifications:
Rocker arm locknut 18 ft lbs
Intake valve - .010
Exhaust valve - .020
Valve Order
TDC Cylinder # 1 In + Ex, 2 In, 3 Ex, 4 In, 5 Ex
BDC Cylinder # 2 Ex, 3 In, 4 Ex, 5 In, 6 In+Ex
Procedure :
Engine must be cold prior to setting the valve lash. Overnight cool off is ideal.
1. Remove the valve cover. There are 5 bolts that hold the valve cover to the head. Use a 10mm socket wrench or nutdriver to loosen the bolts. You will not be able remove the bolt completely. After all 5 are loose pick up the cover and remove the cover. It can be tricky to remove. Be careful not to damage the rubber valve cover gasket.
2. Remove the injection pump drive cover. The cover is simply the round plastic piece that the breather tube connects to on the timing cover. Remove the breather tube from the cover. The cover simply screws onto the timing cover. Rotate counter clockwise to remove.
3. Rotate the crankshaft so that cylinder #1 is at Top Dead Center (TDC). This is accomplished with one of two ways:
3a. One is by using the Cummins Barring tool and a 1/2 in drive. Remove the rubber plug on the front passenger side of the bell housing. Insert the barring tool and turn the wrench. This method engages the flywheel directly to rotate the crankshaft. You can rotate the crankshaft either direction.
3b. The other method uses the alternator nut to rotate the crankshaft via the belt. Use either a 7/8in or a 22mm socket on the alternator pulley nut. Turn the wrench counter clockwise. If you turn the wrench clockwise the pulley will slip and not turn the belt at all. This method turn the crankshaft backward from the direction it normally turns while running.
While using either of the two methods to rotate the crankshaft, you must watch the fuel pump drive gear to line up the timing marks (pictures below). There two markings on the timing case, one marked TDC and one marked BDC. Line up the timing mark on the drive gear with the TDC notch.
4. Setting the valves. Now that cylinder #1 is at TDC you can adjust some valve. Refer to the Valve Order listing to adjust the correct valves for TDC. Here you will need the open end wrenches, allen key set, feeler gauges, and the torque wrench. Start with cylinder #1. For reference the short rocker arm is for the intake valves, and the longer one is for the exhaust valves. (picture 1) The feeler gauge is used where the pivot stud meets the Y piece that engages the valves.
Loosen the locknut on the rocker arm. Insert the feeler gauge, (picture 2) remember to use the proper size, .010 for intake and .020 for exhaust. Now use the proper allen key and adjust the allen head screw in the middle of the locknut. (picture 3) This adjusts the gap (valve lash) between the pivot stud and the Y piece. You will feel a slight drag on the feeler gauge once the gap is set correctly. Then remove the feeler gauge and with two hands hold the allen key steady while tightening the locknut, this is the most tricky part of the procedure. After tightening check the valve lash again and adjust as needed.
Do all the valves listed in the Valve Order for TDC. After that is complete rotate the crankshaft one revolution until the timing mark is at the notch for BDC. Then do the valves listed for BDC.
Tips and Techniques
One great way to make sure of the proper valve measurement is to use what I call the Over Under technique. For example with the intake measurement of .010. A great way to know if you have the adjustment dead on is to use a feeler gauge that is .001 up and down from the intended measurement, so you would use a .011 and a .009 feeler gauge. When measuring the .009 gauge will fit very easily and the .011 gauge will not fit at all.
Another tip is after all adjustment is done to rotate the crank shaft 2 revolutions and check all measurements again. This gives the springs a chance to compress and move the valves.
After all valves are adjusted and checked replace the valve cover and the fuel pump drive cover and replace the breather tube.
Old Aug 12, 2012 | 04:34 PM
RanchhandTCR's Avatar
Here my valve cover and intake horn and boost elbow I painted when I replaced my injectors.
Attached Thumbnails Painting valve cover tips-dodge-valve-cummins-003.jpg   Painting valve cover tips-dodge-valve-cummins-005.jpg
Old Dec 22, 2015 | 05:55 AM
coalconqur's Avatar
Default My newly painted valve cover
check it out. pretty cool huh
also, here is a Youtube video:
Highway Forever!!
Old Dec 30, 2015 | 05:15 AM
gh0stman's Avatar
That does look nice. Here is mine.
http://s1061.photobucket.com/user/ben_harrison4/media/Mobile%20Uploads/2015-04/1D285639-6694-4E6B-A001-0B35EB9A0B91_zpsto0rbchv.jpg.htmlIt has that brushed aluminum look from the sanding process.
mrh1282
For Sale
Jul 20, 2015 04:27 PM
LTreis702
Feb 14, 2015 12:52 PM
cmalson
Nov 29, 2014 12:57 PM
woodsman27
Oct 26, 2014 02:13 AM
flogrownstroker
Oct 6, 2014 01:19 PM
