Trans Trouble....Help!?!?
Old Jul 26, 2012 | 04:00 PM
firstgenfreak93's Avatar
Default Trans Trouble....Help!?!?
Hey, i took my 91 out for a drive yesterday and it was runnin fine. it had the trans rebuilt to spec by the previous owner last summer. it still has that little "kick" when shifting from first to second but smooth the rest of the way...(automatic) i pulled onto a rural gravel road and turned around to head home....and it wouldnt shift out of first gear....i drove about 7 miles at 12 mph and then as i was goin down a little hill it shifted into second...i slowed down and let it shift back to first and got it home....checked the trans fluid and it was actually way to full....could that be causing it to slip....what is the problem and what will it take to fix (parts,time,money)please tell me what you think...
Old Jul 28, 2012 | 01:27 AM
flyingcrodeo's Avatar
It havin to much could cause a problem (so i've heard) but when you checked your fluid level did you leave it running and in neutral when you checked it?? Or just in park?
Old Jul 29, 2012 | 01:23 AM
Gas's Avatar
Gas
Pull the pan and change filter, adjust bands (both) and put a bottle of Lucas in the pan before bolting it back on. Add ATF+4 and go for a 20 minute drive to get it hot then check level hot in neutral. Should be between full and add not pegged at full.
Old Jul 29, 2012 | 12:09 PM
NKY 1stGener's Avatar
The fluid being overfilled could be the problem, or it may need to be changed. It could also be something to do with your kickdown cable, might need to be adjusted. Id try looking at that.
Old Jul 31, 2012 | 01:18 PM
I drained some of the fluid it is now at the right level and it was shifting a lot smoother and pulling hard....it ran great....not sure what happend but its fixed now!
Jake9473
Jul 22, 2018 08:19 AM
Rabbitjbu
Jul 28, 2015 06:03 PM
Nu2cummins
Jun 26, 2015 02:30 PM
yfzrunner
Feb 7, 2015 10:52 PM
Pyrohigh
Oct 11, 2014 07:59 AM
