Disconnecting Lockup By Brake Pedal?
Old Feb 28, 2008 | 07:54 PM
len70's Avatar
Default Disconnecting Lockup By Brake Pedal?
i'm trying to figure out how to disconnect the lockup by using the braking pedal to trip the momentary switch. i'm confused because your actually breaking ground, correct? do i use a standard 30amp relay,feed it power,then use ground side off the relay hooked up to the switch. will this trip the momentary switch? or will it feed through the switch down into the computer. i'm doing this on my 06 ctd
Old Feb 28, 2008 | 07:55 PM
Why do you want to unlock the converter?
Old Feb 28, 2008 | 09:08 PM
len70's Avatar
i want to use the brake to unlock the converter so i don't stall the truck when i come to a stop (in case i forget to hit the switch )
Old Feb 28, 2008 | 10:56 PM
RSWORDS's Avatar
hmmm.... Good Idea.... Can;t wait to see how it works out!
weatherby
Aug 31, 2015 08:04 PM
Turbo67
Jul 25, 2015 02:26 PM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
PowerStrokin94
Mar 21, 2015 07:15 PM
yams
Nov 29, 2014 09:25 PM
