Turn Up An Injection Pump On An 84 6.9 Diesel
Old Feb 28, 2008 | 07:19 PM
black smoke's Avatar
Default Turn Up An Injection Pump On An 84 6.9 Diesel
yes i heard you can turn up your injec pump on 6.9 diesel does anyboy now how? and where is the injector located on the truck its a 84 ford 250 6.9? please email me at plisonbee@hotmail.com with any coments or advice please thank
Old Feb 28, 2008 | 10:32 PM
LOGANSTANFORTH's Avatar
the thread directly below this one......
Old Feb 28, 2008 | 10:50 PM
Benjamin's Avatar
Bombardier
https://www.dieselbombers.com/ford-8...cal-motor.html
Old Feb 29, 2008 | 07:00 PM
wtfd6's Avatar
Bombardier
are you adding a turbo? adding more fuel isnt really going to give you much more power. the injectors in these trucks only pop at 136 bar. and are pintle style. nothing compared to the 5-7 hole injectors out there. then injectors are just inside the valve covers. the lines that run from the pump go right to them.
Old Mar 6, 2008 | 10:13 PM
Default 84 f-250 6.9 hard starting
im wonder if its normal for this year and engine to have a hard time starting in the morning i live in utah county in utah. i bought a kats radiator heater that i plug in at night, i replaced the glow plugs. ive tried to push the glow plug plug a couple times to try to help get it fired up. last resort is spraying starter fluid in airfilter. and that starts it right up. oh also i just replaced the alternator and fully charged my batterys. so if anybody have some helpfull advice or experience of there own with same or close year of truck. please email me at plisonbee@hotmail.com thanks tons
Old Mar 6, 2008 | 11:12 PM
DBogo's Avatar
IDI's dont like the cold much at all, its pretty normal for them to be a pig to start when its below freezing, your timing might be slightly off with it
Old Mar 7, 2008 | 01:54 AM
be careful doing that, one big gulp of ether into a single cylinder and bang.......
Old Mar 11, 2008 | 06:22 PM
Default hard starting 84 6.9
if my glowplug timer is go on and off when i push the botton thats means working that would mean that im getting power to my plugs right???? or not.could that still mean that i have a short some where in the line?/ pre owner rig it so that the glowplug dont start with the ignition key its seperate button underneath ... so im supper confused i figure that the botton and glowplugs work if I can hear the timmer turn on and off but this is my first diesel so im probable totaly wrong.... also i changed out the fuel fiter and ran tranmistion oil in it and let truck idel for about 1/2 hour.. i heard thats the best to clean out the injectors but havent tried to start it since.. thanks
okay so i just tested the glowplug connectors and they tested out about 6 omh.. is that good or bad. and when testing the conectors do i need to be pushing the glowplug botton? does that make a tons different..
Last edited by black smoke; Mar 11, 2008 at 06:22 PM. Reason: Automerged Doublepost
Old Mar 26, 2008 | 12:42 PM
RTL Garage's Avatar
Did You Solve Your Issue?
Old Mar 26, 2008 | 10:46 PM
FordGuy100's Avatar
I would set your gp up on a manual switch, so you can control them. The 6.9 controlers fail ever so often, and the glow plugs never really get hot.
Never start it up with ether and glow plugs, thats a combo made for a disastor. If you have to start it up with ether, make sure you glow plugs arent working.
You can get a lot of power from turning them up, even N/A, the only problem is that EGT's will get crazy high fast in N/A form. They can run up to 1200* stock, so be careful.
Your glow plugs are good, it just sounds like your glow plug controller isnt working (to my knowledge).
Mine has started down to 16*F, but it turns over a little slow due to bad battery cables. I'm sure I could go down to single digits without a real problem, it would just take a good amount of cranking (took a good 8 seconds for the 16*F, but you could count the rev's, so its turning over to slow).
