DTT Assassin Fuel Pump Pressure Problem
Old Jul 23, 2012 | 08:20 PM
RPM's Avatar
RPM
Default DTT Assassin Fuel Pump Pressure Problem
I put my fuel pump on today but I have some pressure issues. It starts out about 7 pounds at idle, 16 pounds at 1500 RPM, 18 pounds at about 2000 RPM. I took my wife down to a body shop to drop her car off, about 3 miles round trip. By the time I got back to the house it was at 3 pounds at idle, 7 pounds at 1500 RPM. I bled the air/water from my filter (Stock filter) nothing changed except this time I took it around the block and it was back to 3 PSI.
Can someone help me out on how to fix this, do I need to tweak the spring in the regulator? I called DTT at 4 PM west coast time but didn't get an answer. They must have gone home early. I need to fix this quick as I am down to one car.
Old Jul 23, 2012 | 08:33 PM
Dodgemanstan's Avatar
Wow that sounds mind boggling! I dont even know what to say....
Old Jul 23, 2012 | 08:35 PM
turbo20psi's Avatar
That pump runs low at idle and should increase with RPM's . You can adjust it, it has a regulator on it to adjust the pressure. Idle pressure should be no lower then 5PSI.
Diesel Transmission Technology - DTT Performance Diesel Transmission and Power Accessories
Old Jul 23, 2012 | 10:32 PM
RPM's Avatar
RPM
I figured it out. I am getting some debris in the regulator from the install. I have cleaned the spring actuated regulator out twice tonight.
I need to figure out what I can do in the long term. I was thinking about a small can type filter between the pump and tank for a while.
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
