lift pump supply line leak?
Old Jul 23, 2012 | 06:31 PM
RamblinWreck's Avatar
Default lift pump supply line leak?
While accelerating under 1/2 throttle or more the fuel pressure will sometimes drop from 12 psi to 8 or lower, I let off of the accelerator pedal and the fuel pressure comes back to 12. I've replaced the fuel filter within the last couple of thousand miles and it does not do it consistently. It acts like there is a leak in the supply line to the lift pump that lets air in so it loses prime. I've got an Airtek fuel pump that was put on 2-3 years ago.
Any suggestions/thoughts? Are there o-rings that should be replaced? I don't have any fuel leaks.
Old Jul 30, 2012 | 10:20 PM
Looking at other posts, it sounds like a draw straw problem. The tank is less than 1/2 when I see the problem.
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
