TWINS!!! Or NOT...
Old Jul 21, 2012 | 07:50 PM
Dodgemanstan's Avatar
Default TWINS!!! Or NOT...
SO I got the idea after searchin around for a bit...Never done this or even thought about it but whats the best option for me.... Keeping my stock turbo and getting another one to compound it, or getting a different turbo completely... What would be the price on getting a twin set up using the stock turbo or is that possible.... Plans do include ARP head studs FYI.. Just wanting to brand out a little and open the option up for 2 turbos on the cummins! Thanks!!
Old Jul 21, 2012 | 10:42 PM
cummin_un_glued's Avatar
FormerVendor
with your current fueling a S362/65/14cm would be plenty. with some 150hp injectors a S363/68/14 would be plenty. if you want to compound your hx35 then you could use a S471 as the bottom charger i wouldnt recommend going any larger then that for a primary charger. RAWilliams on here is running that setup now and really seems to like it. i can get you pricing for any of the above options but you can count on the compounds costing $1000 more easily.
Old Jul 22, 2012 | 09:41 AM
Yea I kinda thought the same thing... 150 sticks are coming soon!
Old Jul 22, 2012 | 09:50 AM
empty wallet's Avatar
What is your goal?
Old Jul 22, 2012 | 10:39 AM
If I only knew.... ha
I want super durable daily driver with power when I need it.
Eventually 500-600 hp or more if money is good.
Old Jul 22, 2012 | 05:57 PM
01quadcab's Avatar
best bet it to buy a 62 then later add a 475 to the bottom and you will hit your goal and have a daily driver.
Old Jul 22, 2012 | 10:29 PM
FormerVendor
^^^ this for sure if your planning on 500-600hp that you can really use.
12 valve 97
5.9L 12V Performance
21
Jan 27, 2016 04:59 PM
