code help
Old Jul 21, 2012 | 10:48 AM
hounds24's Avatar
Default code help
i checked codes on the dash and p 0460 and p 1693 came up what does it mean? 01 2500 Thanks
I am going to bump this and ask if anybody has used a fass ddrp? i dont think p0460 is a lift pump problem, prob sending unit, but i think i will replace lift pump because i dont hear it cycle if i bump the starter?
Old Jul 21, 2012 | 10:45 PM
dasnumnum's Avatar
I got a few codes and after someone ran over my reader i decided to make use of the monkey at autozone. They will read the codes for free and give u a receipt which usually tells u what the code means.
I got the 1693 im sure of it and i believe its a companion code which means another code could be thrown and wont show through the dash. Need to use a OBDII scanner pronto!
0460: Fuel Level Sensor Circuit Malfunction...bad connection or bad sending unit?
TroubleCodes.net- engine & OBD2 Trouble Codes and Technical info & Tool Store.
Ill bump this for ya because thats all i can help with. Good Luck
dwmeehan
Sep 6, 2015 04:20 PM
Saams69
Jul 20, 2015 11:21 PM
flash7210
Jul 5, 2015 09:25 AM
robbyS
Apr 16, 2015 02:22 PM
Backhoeman
Jan 3, 2015 12:53 PM
