1995 Ram 2500 Steering problem, please help!
Old Jul 19, 2012 | 08:43 PM
12VALVECOUNTRYBOY's Avatar
Default 1995 Ram 2500 Steering problem, please help!
The truck in my signature just started gettin a bind in the lower U-joint on the steering shaft and it pops kinda bad. Only thing im worried about is what i gotta replace. Is there anyway to tell whether its the shaft or the box. The u joint has very little play but its just enough to put it in a bind.
If yall have some advice id greatly appreciate it. Thanks!
Old Jul 20, 2012 | 01:27 PM
1AMatt's Avatar
Site Sponsor - 1aauto
I havent heard of too many steering shaft issues with these trucks... I have heard of PLENTY of steering box, and steering component issues
Old Jul 24, 2012 | 07:41 PM
Gbodman's Avatar
What made you diagnose it as stemming from the lower u-joint in the steering shaft? Kinda a strange diagnosis... Has the frame ever been pulled after a collision?
Old Jul 26, 2012 | 12:29 PM
1AMatt's Avatar
A bad joint in the steering shaft might cause a tiny bit of play, but I can see it being that bad
Old Jul 26, 2012 | 01:55 PM
1stgen12valve's Avatar
is the box lose
Old Jul 30, 2012 | 06:14 AM
The box is tight and doesnt move. When you turn the wheel, there is a little resistance and then a pop. So i got under and looked while someone turned the wheel. And the lower steering shaft ujoint has some play in it. Therebis a little bolt in it to tighten, but it wasnt loose. I dont know exactly how that shaft attatches to the box but it seems to me that the lower half of te u joint slides directly down over a pin coming out of the box, and the play in in the u joint is coming from the joint not being tight in that pin.
burndiesel
10
Feb 7, 2023 01:15 AM
Dec 29, 2014 10:20 AM
Dec 5, 2014 05:50 PM
Nov 24, 2014 08:20 AM
Oct 24, 2014 02:50 PM
