injector nozzles again
Old Jul 19, 2012 | 07:36 PM
holset cummins's Avatar
Default injector nozzles again
i did a write up about this before but now i have different problems. i found a company what sells 7 hole injector nozzles in 50hp and 100hp. the chip i have isnt that big so i would go with the 100hp but once in a while the truck is used to tow a racecar or two around the state so i dont want my EGT's going crazy. i was wondering if i could just unplug the tuner when i do go on long trips with heavy loads and be fine if i get the 100hp. the truck is mostly just used as a dialy driver but i am just worried about egt's when that time comes. let me know what you guys think. thanks
Old Jul 20, 2012 | 11:30 PM
cummin_un_glued's Avatar
FormerVendor
yes that will work and your egts should be fine
