stock HG with studs?
Old Jul 19, 2012 | 07:27 PM
turbo2332's Avatar
Default stock HG with studs?
how hard can you push a HG with just studs? which studs do you all recommend? funds arnt there right now to do al the machine work and i would much rather just stud it 1 at a time if i will benifit from it?
thanks
also what about the mighty diesel head bolts?
Old Jul 20, 2012 | 09:31 AM
Drothgeb's Avatar
I made 20 passes with the MD bolts @ 135lbs running 90psi+ on the original gasket. The gasket finally let go when I raised the timing to 26*.
Old Jul 20, 2012 | 10:05 AM
turbo2332's Avatar
im at 17* and soon to be running a 63mm turbo. i havent heard many bad things about these bolts and for $130 they are much more affordable.
Old Jul 20, 2012 | 01:32 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Woah... Sounds like the hold up pretty good! I didnt realize they would hold up so well with just stud
Old Jul 20, 2012 | 02:21 PM
94 12valve's Avatar
All depends on your set up and what your going to do with the truck. If your in the market for studs ARP gets my vote, I've had great luck with there 12mm studs.
Old Jul 20, 2012 | 02:36 PM
turbo2332's Avatar
im in the market for not pulling off my perfectly good head! so i want to keep it that way before something happens. just dont want to have to drop big $$$ for a name if it gets me know where but braggin rights. i just want the truck to hold together.
Old Jul 22, 2012 | 07:54 AM
Drothgeb's Avatar
The MD bolts are good for the money, and for most builds they would work well but, the ARPs are a step better if you need it. If you need more than that, there are other choices too. I ended up going with Extreme Studs. They were more than the standard ARPs, but I went with double O-rings, so I wanted something as strong as possible, with out being outrageously expensive.
Old Jul 22, 2012 | 09:15 AM
cummin_un_glued's Avatar
FormerVendor
^^^ extreme studs is my vote. we recently made the switch from ARP to extreme for our builds. we also have them in stock.
Old Jul 22, 2012 | 09:37 AM
biged681985's Avatar
I want to caution you about Tony's head bolts. I'm one of the few who have used them and not worked. I was sitting at 433 go on a stock charger, pushing it past it's limits, and ended up stretching 8 bolts on my 12v. But like I've said, I'm one of the few who have had a problem with them. My personal preference is drop the little extra coin for studs. U won't regret it
Old Jul 22, 2012 | 01:38 PM
turbo2332's Avatar
do you think in your situation they held up better than the factory bolts?
