4 wheel disc brakes?
Old Jul 19, 2012 | 02:40 PM
joecool911's Avatar
Default 4 wheel disc brakes?
I have a 2001. It has 4 wheel disc. Nothing in my repair manual on disc brakes. It's a chiltons or Haynes. Should I get a 2002 and later for some subjects? Anyone have a good link to rear brake pad replacement?
Old Jul 19, 2012 | 03:46 PM
wyodiesel92's Avatar
Same as doing fronts, dont let anyone fool you into thinking its harder same design just smaller and on the back basically
Old Jul 20, 2012 | 04:36 PM
joecool911's Avatar
Can you replace the pads without pulling the calipers?
Old Jul 20, 2012 | 11:25 PM
Nope. Well technically you can pull one bolt and swing the caliper up or down and put your pads on the bridge but pulling both caliper bolts makes it easier.
Old Jul 21, 2012 | 12:56 AM
tiremann9669's Avatar
Some rear calipers the piston turns in instead of pushing in, don't know about a truck never had one with rear discs. If the pistons wont push in you can borrow the tool to turn them in from autozone.
Old Jul 21, 2012 | 08:01 AM
The ones on these trucks are standard caliper and just have to be pushed in. Your referring to a ratcheting caliper found on vehicles without a separate set of brake equipment for the parking brake. a ratcheting caliper acts as a standard caliper without the parking brake applied and when you set the parking brake the piston will compress then release when pb is released. Think of it like how drums are setup on the rear but instead its with calipers. The biggest vehicle i have ever seen them on though was a mini van. Definately not on a truck.
Old Jul 23, 2012 | 08:04 PM
turbo20psi's Avatar
Just a note you have a 2001.5. Half way thought the year dodge put disc on the rear. It matters when you are looking for parts IE brakes.
Old Jul 23, 2012 | 08:07 PM
joecool911's Avatar
I wiz wondering if it might be a 2001.5. Was not sure where the cutoff was. Good to know. So it sounds like I might need a manual that covers 2002. My manual is pretty much worthless.
cutthroatxxx
Jun 22, 2015 10:16 PM
Radioking1777
Jun 9, 2015 04:13 AM
thatdude38
May 9, 2015 12:21 PM
kryz9903
May 4, 2015 05:00 AM
6.5dieselman
Feb 26, 2015 04:45 PM
