Priming fuel system
Old Jul 18, 2012 | 11:10 AM
1999stroker's Avatar
Default Priming fuel system
How can I prime the fuel system after changing my fuel filter? I don't have an extra set of hands at the moment. Is there a simple way to do it? Please help
Sent from my dumb phone!
Old Jul 18, 2012 | 11:14 AM
wyodiesel92's Avatar
Bump the starter a few times with everything tight and after a few times start the truck. May run a little rough at first but bring up the rpms for a little and you'll be good.
Old Jul 18, 2012 | 11:15 AM
RAW's Avatar
RAW
Turn the key on, bump the starter (but not not let the engine start), and let the key rest in the run position. This will run the lift pump for aprox. 25 seconds. If that doesn't get all the air out, crack the return line banjo bolt on the injection pump and do it again until fuel comes out.
Old Jul 18, 2012 | 11:19 AM
Where's the return like raw?
Old Jul 18, 2012 | 11:22 AM
And Wats the size? 3/4?
Old Jul 18, 2012 | 11:28 AM
RAW's Avatar
RAW
19mm or 3/4"
Old Jul 18, 2012 | 11:47 AM
Can hear pump running but won't turn over
Old Jul 18, 2012 | 11:51 AM
turn it over until fuel comes out of injection pump or line?
Old Jul 18, 2012 | 12:00 PM
RAW's Avatar
RAW
If you loosen #4 half a turn to 3/4 of a turn, air will come out with the lift pump running. Fuel will follow when the air is out of the system. If you can't get fuel or air from there, try the inlet, #3.
Well I tried that and no luck. Fuel was dripping out of IP but couldn't get her to fire
