HTT turbo
Old Jul 17, 2012 | 09:04 PM
jake 94's Avatar
Default HTT turbo
Hey everyone just wondering ur guys thoughts on high tech turbo??? Are they any good? I'm lookin to downsize on turbo to lower my egts and I need to start towing more with my job. I'm looking at a 62/71/13. How do you guys think that would work with my set up? Think I can run it with my 7x012s or should i put my 150s back in for now? Thanks in advance!!
Old Jul 17, 2012 | 09:08 PM
cummin_un_glued's Avatar
FormerVendor
i think it would run great with a S363/68/14 and you can get the same turbos from other places for less money
Old Jul 17, 2012 | 09:38 PM
jake 94's Avatar
Hey Dustin. How much are those 63's?? I'm gettin this turbo for 1000 bucks from a buddy
Old Jul 17, 2012 | 10:07 PM
Smarty=Cummins's Avatar
The 63-68-14 is a good turbo with my setup got it from torque diesel.
Old Jul 17, 2012 | 11:05 PM
jake 94's Avatar
What do you run at for egts just cruising?? I'm tryin to lower my egts and still be able to tow. In startin to tow more for work and this 64 doesn't like to pull anything unless I'm spinning 2k rpm. And I've got a bit more fuel then you. How does it spool down low?
Old Jul 18, 2012 | 12:32 PM
It takes about 5 seconds to get it to spool up from a dead stop which leaves a nice cloud of smoke. I Havnt had it hooked to any trailers yet but I think it will work for towing.
Old Jul 18, 2012 | 12:52 PM
FormerVendor
Jake the problem with your current charger is the turbine size. The 74s are lazy.
Sent with a Droid RAZR in one hand and 14,000 volts in the other.
Old Jul 18, 2012 | 04:31 PM
jake 94's Avatar
How much are ur 63s dustin I only have about 1000 to spend
Old Jul 18, 2012 | 05:17 PM
FormerVendor
pm sent
Old Jul 18, 2012 | 10:48 PM
01quadcab's Avatar
the 62/71/14 can be a little lazy for towing but it will sure beat the heck out of the 64.
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
