Fuel Pressure Gauge
Old Jul 17, 2012 | 12:26 PM
EvanBoothe's Avatar
Default Fuel Pressure Gauge
I there a good DIY anywhere on how to run your fuel pressure gauge? Or can somebody tell me how. Thanks
Evan
Old Jul 17, 2012 | 12:49 PM
empty wallet's Avatar
What gauge do you have?
Old Jul 17, 2012 | 12:54 PM
EvanBoothe's Avatar
Have not bought one yet, I am tomorrow evening from summit racing any suggestions. And a how to install it
Old Jul 17, 2012 | 01:01 PM
ISS Pro is top notch but autometer is good too. Get a 30psi gauge, make sure you get a snubber. They come with instructions- wiring varies by brand but it's pretty simple.
Old Jul 17, 2012 | 01:32 PM
EvanBoothe's Avatar
What's a "snubber"
Auto Meter 4412 - Auto Meter Ultra-Lite Analog Gauges - Mobile SummitRacingEquipment.com
How about thos
Last edited by EvanBoothe; Jul 17, 2012 at 01:32 PM. Reason: Automerged Doublepost
Old Jul 17, 2012 | 02:21 PM
H.R.D's Avatar
IMO the range is to high on that gauge, it won't give you the best accuracy like a 30psi gauge will. But it will work for sure.
TORK TEK 12MM BANJO BOLT PRESSURE GAUGE SNUBBER PN BBS010 - Tork Teknology
Old Jul 17, 2012 | 02:23 PM
EvanBoothe's Avatar
So thats what that snubber will fix
Old Jul 17, 2012 | 03:18 PM
H.R.D's Avatar
The snubber will fix the needle bouncing all around on the gauge itself. They are caused by violent pressure spikes which can destroy an analog gauge.
Old Jul 17, 2012 | 04:27 PM
EvanBoothe's Avatar
Okay, I'm guessing summit will have a snubber? And also could I splice the fuel line going into the injection pump, get a T fitting and then screw the snubber on top of that?
Old Jul 17, 2012 | 04:36 PM
H.R.D's Avatar
If you get the one I posted up earlier, the Tork one you will be set. But yes I am sure summit will have them. Yes you should be able to plumb it in using a T fitting, I don't have one I have digital gauges. The best place to put it is right at the inlet of the IP like the Torks one goes.
