vp died...go from ho pump to so?
Old Jul 16, 2012 | 10:36 PM
wyodiesel92's Avatar
Default vp died...go from ho pump to so?
Okay so driving down the interstate and all of a sudden truck coughed and died. 16psi to pump, tried bleeding injectors and nothing. Towed it home and got..
P0237
P1688
P1689
P0252
P0253
So ip is condemed dead.
Now i need to order a pump and im trying to figure out if i can get a SO pump to replace the HO pump? Is it straight forward with no issues?
Old Jul 17, 2012 | 08:01 AM
EggosBrother's Avatar
Im sure a vendor will chime in with a definate answer but, when i read the fine print on a few sites it says HO core for New HO and SO core for new SO. I was thinking about going the other way when mine dies
Old Jul 17, 2012 | 08:45 AM
RAW's Avatar
RAW
Core may be an issue, otherwise it's a direct replacement.
Old Jul 17, 2012 | 11:36 AM
Farmboy 2.0's Avatar
I dont think core would be a issue
Old Jul 17, 2012 | 12:52 PM
empty wallet's Avatar
You can swap no problem. Don't mention it's an h.o although I doubt it's an issue.
But seriously man, you have some bad luck
Old Jul 17, 2012 | 05:07 PM
Yeah it sucked was on my way to casper with my buddies 10,000 dollar tool box and 30,000 worth of tools in my bed helping him out and going to a job interview to peterbilt up there and made it maybe 80 miles and was pulling a small hill in traffic with semis and all of a sudden it died. Didnt see fuel pressure or anything drop. May i add finishing the hill and coming to a stop on the side of the interstae at 80 with no power brakes was a whole lot of fun getting flipped off and all haha.
I talked to blue chip diesel about getting the level two pump with remanufactured and updated computer and all updated internals that are presently available instead of the basic rebuilt pump and he said they'd take my ho pump as core for a so pump just to make sure i order the so pump since they have 3 different part #'s per pump.
Best part was on the side of the road trying to see if i could bleed the pump with semis and idiot drivers flying by. Further diag found ive only got fuel coming out of 1 or 2 lines so the pump definately bit the dust hard. Just worried the air dog might have caused an issue because after the truck died i had to pull battery cables to get the ad to start working again. Thinking there might have been an issue with it attached at the battery. Going to swap it to the alternator when the new pump gets here.
This last two months has just been alot of bad luck with the wife in and out of the hospital thinking she has ms and just lots of other things, and ofcourse it crapped out when i didnt have money to get it.
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
Renteria1217
Apr 16, 2015 11:38 PM
greenbomb
Jan 23, 2015 10:36 PM
