Manual to Auto
Old Jul 16, 2012 | 09:19 AM
scottmorgan's Avatar
Default Manual to Auto
i am interested in changing my manual 6 speed out for a auto. what will it take?(CPM,Links. ect)
please be very detailed.
Old Jul 16, 2012 | 12:10 PM
Dodgemanstan's Avatar
Stay with the Manuel!!! Don't go to the dark side.....You will regret it..
Old Jul 16, 2012 | 12:16 PM
why is it so bad? i am looking at a tripple disk, shift kit, vavle body upgrades, upgraded clutches with only 20,000 miles on it. for a straight trade...
Old Jul 16, 2012 | 01:25 PM
cummin_un_glued's Avatar
FormerVendor
What year is the truck? Is it 4wd? If so you will need to change the input shaft in the tcase. Drive shafts will need modified 3" each because the auto is shorter. Your cross member is the same. The linkage to the tcase will be too long also. You will need an auto pcm and wiring. Also you will need a flex plate.
Sent with a Droid RAZR in one hand and 14,000 volts in the other.
Old Jul 16, 2012 | 01:38 PM
that helps alot... will i be better to ask and trade drive shafts flex plats and pcms with this guy mine is a 2001 and his is a 1999 i have the dana 80 rear end is the shafts diffrnet or maybe the u joints? what about a floor shifter that will fix the hole in the floor and it will alow me to keep my steering colom... pcm why do i need to change it? cruise... passing gear?? linkage on the 4x4 will be fine due to the fact that i will undo the wing nut and slide the rodd forward 3"... i could use his tcase right?
and i have the H.O. will that make my PCM diffrent?? the fuel pump and fly wheel is about the only diffrence i think...
Last edited by scottmorgan; Jul 16, 2012 at 01:38 PM. Reason: Automerged Doublepost
Old Jul 16, 2012 | 05:03 PM
RollinCoal99's Avatar
all i have to say is why....
Old Jul 16, 2012 | 05:50 PM
FormerVendor
if both of your trucks are the same wheelbase then swap as much as possible, i think you can just swap the ujoint on the rear shaft on the pinion end. yes you can just swap cases with him and swap linkages. you will need an auto pcm without it the trans will only shift 1-2-3 and will not lock the TC at all. even with it you will likly have to add a relay at the fuse box for the TC lockup to work correctly and that is assuming that the wiring from the pcm to the fuse box already has that wire in it which i would think that it does. the pcm dosnt care if its an SO or HO thats just in the board on the pump.
Old Jul 16, 2012 | 10:07 PM
You would better off buying a different truck if you want a auto.... The work and money involved would be ridiculous!!!! Just keep the manual or trade yours in for something else.... Just some wise advice...
Old Jul 17, 2012 | 03:31 AM
pukie370's Avatar
the manual 6 speed truck is worth about 4000$ more!
Old Jul 17, 2012 | 07:57 AM
No way,?? here in MO you can find some Really NICE cummins for around 10k... 6psd or auto I bought my 02 6pd with 133k for 5250 and its was show room floor condition... Where you located?
