Homemade Dual Fuelers
Old Jul 15, 2012 | 08:41 PM
2004LB7's Avatar
Default Homemade Dual Fuelers
thought you might like to see my home made dual CP3 setup
Bracket, CP3, high pressure line, and pulley. i made the pulley setup by welding a harmonic balancer to the gear.
this is the line i made. i cut two injector lines and welded them together and bent it to the required shape. risky i know but still leak free, and holding up
i ended up using a different CP3 and making a longer high pressure line. here it is running.
so far the cost has been:
CP3 - $100 ebay
harmonic balancer - $13.00 Pick & Pull
Dual CP3 controller - $200 ATS
obviously it is over kill for my setup. i am limiting the fuel via my tuning so as to not blow up my engine. i did it because i ended up with a spare CP3 after a project so i put it to good use
Old Jul 15, 2012 | 11:12 PM
H.R.D's Avatar
Looks slick, just be safe my friend.
Old Jul 16, 2012 | 12:03 AM
2004LB7's Avatar
i hear you. some of the tests i did were commanding max psi for several minutes to make sure none of the lines leaked or burst. i also revved the engine to 4500 rpm, testing for vibrations, etc. in no way were these scientific tests but helped me feel more confidant in the build
Old Jul 16, 2012 | 12:59 AM
H.R.D's Avatar
Old Jul 17, 2012 | 10:23 AM
1AMatt's Avatar
Site Sponsor - 1aauto
Very nice man
Old Jul 23, 2012 | 11:19 AM
2500HeavyDuty's Avatar
i hope that line holds up, im sure it would. there are a few companies than can bend a line for you you just have to send them a line made out of brake tubing so they can bend you the real one.
But very nice job
Old Mar 8, 2020 | 09:57 PM
Francis Courchesne's Avatar
Default Pulley
Great build. What car or truck came the harmonic pulley?
Old Mar 9, 2020 | 12:00 AM
2004LB7's Avatar
I have no clue anymore. Too many years ago
Mar 11, 2014 08:10 AM
JesseRohr
6.4L Performance
17
Feb 13, 2010 07:07 AM
WyoD-MAX
19
Aug 1, 2009 08:45 AM
rkadcock
5.9L CR Performance
10
Jul 25, 2009 09:06 PM
Super Dave
5.9L CR Performance
11
Jan 14, 2008 10:20 PM
