06 coolant leak
Old Jul 13, 2012 | 08:30 PM
minncountryboy's Avatar
Default 06 coolant leak
Anyone ever encounter the little coolant hose by the turbo? Mine started to drip a little and I was thinking bout tightening up the hose clamps first.. but thought bout changing the hosr completely since its right next to the turbo.. anyone ever change it? Called a stealership and they said you have to take the back section of hard pipe completely off to change a 3-4 f***in hose which i think is b/s
Old Jul 13, 2012 | 09:05 PM
Captain Call's Avatar
Mine was leaking just enough to get a wiff of antifreeze. A couple turns of a nut driver and all is well. I will add that I was loosing antifreeze too, the problem is there were no wet spots.
Old Jul 13, 2012 | 09:25 PM
Ahh mines not leaking alot but just enough to were i can notice it drippin on the side of the block and wet spot on the bottom side of the hose
Old Jul 19, 2012 | 04:30 PM
Matt5005's Avatar
I had it on mine, got a small piece of hose and fixed it myself. it was a bitch but it was cheep fix.
Old Jul 20, 2012 | 06:27 AM
K80's Avatar
K80
I tightened the hose clamps on mine. That fixed it.
Old Jul 20, 2012 | 12:53 PM
steved's Avatar
Silicone hose that connects the two sections of hard pipe? It only takes a minute to remove the hard pipes. I completely eliminated mine...I used a 5/8" heater hose and needed a 5/8" barb x 1"MNPT fitting at the pump...no more multiple sections of pipe/hose and its away from the manifold.
Old Jul 20, 2012 | 05:17 PM
jrichard5.9L's Avatar
Mine is doing the same thing but the hose is leaking from 3 small pin holes. I think this time I will get my tubing cutters and cut the hard line back enough to make it easy to work on and replace with 5/8" radiator hose.
Old Jul 20, 2012 | 07:40 PM
06blackXcab245's Avatar
mine was leaking too hose clamps tightened an no more probs, but the hose shouldnt be that hard to change. could probably get it on without taking the hard line off too. i bought the hose just havent changed it yet
Old Jul 20, 2012 | 08:01 PM
I am pretty mechanically inclined but I must say that little piece of hose put up a pretty good fight. I thought I would have knocked it out in five minutes but that wasn't the case. Although I didnt completely remove the hard line just loosened it on the bottom side to give me some room.
Old Jul 23, 2012 | 10:57 PM
Same here dude I thought it was gonna be an easy fix but granted the hose put up a fight haha problem fixed...
