gas pedal problems
Old Jul 13, 2012 | 02:08 PM
Morgan Gray's Avatar
Default gas pedal problems
in my 1994 Dodge Ram 2500 im having problems with the gas pedal its extremely touchy and it will go to the floor and wont come back. Also the throttle cable is a little loose for some reason, any suggestions on what to do or how to fix it?
Old Jul 13, 2012 | 02:49 PM
JBearSVT's Avatar
The throttle cable should have a spring on the end to keep preload on them. I've seen mechanics take them off and throw them away when installing a new cable because you really don't need it... until the cable gets old. Sounds like the spring in your TPS perch might be toast too though.
Old Jul 20, 2012 | 11:12 AM
gyayo2012's Avatar
i have the same isue but the pedal only gets stuck when the motor is off, when the truck is running its springs back fine but the pedal is touchy *** hell any little tap sends her off... idk what the isue is ive tryed adjusting the cable put a new one on..... i just deal with it.
Old Jul 20, 2012 | 11:28 AM
Cordova2013-12 Valve's Avatar
It's just a missing spring on the throttle linkage my friend. You know how the plate your cable attaches to is shaped like a diamond? Well on the other end of the diamond from the ball joint where your throttle cable attaches to is a couple of holes, one of which is where a spring is supposed to be.
moroza
Mar 29, 2015 05:37 PM
Moly Squid
Mar 28, 2015 04:26 PM
Zachbishop
Feb 10, 2015 10:23 AM
Jan 28, 2015 12:10 PM
krinderhagen
Dec 31, 2014 07:12 PM
