help me get started on a 1999 24 valve please
Old Jul 12, 2012 | 02:44 PM
brandon1481's Avatar
Up help me get started on a 1999 24 valve please
im about to buy a 1999 24 valve that is bone stock. and its an automatic with a rebuilt transmission. does anyone have any tips? or what i should put into it performance wise. im wanting it fast at the same time it can pull. thanks!
Old Jul 12, 2012 | 03:05 PM
Willy Muhr's Avatar
Beware of the "53" model block, very prone to cracking on the passenger side of the block and leaking water, if it is cracked, it is usually noticeable by looking under the exhausmanifold, a new block is need if this is the case. i liked my quadzilla pulse with adrenaline on my old 99, cheap and decent power. hope this helps
Old Jul 12, 2012 | 03:28 PM
RAW's Avatar
RAW
53 block for sure, last time the front end was rebuilt, last time the transfer pump was changed, and condition of the injection pump. Was the trans a standard rebuild, or was it built up? From the factory, these transmissions are very weak.
Old Jul 12, 2012 | 05:11 PM
Cool J 44's Avatar
Invest in a chip and then go from there buddy!!
Old Jul 12, 2012 | 06:54 PM
RAW's Avatar
RAW
That's what most do, then they complain about a failed injection pump. Upgrade the fuel system first. $500 at the start can save you $1000+ down the road.
Old Jul 12, 2012 | 08:02 PM
chad83181's Avatar
He's spot on lift pump first, then guages, chip last if anything unless your rich.
Old Jul 15, 2012 | 12:45 AM
I found out that its not a 53 block. Which is good news. And I'm selling my half ton dodge for 4000 next week. So I may put half in the bank and half torwards it. I've been told to buy an air dog 150 for about 500 dollars
Old Jul 15, 2012 | 10:53 AM
1999stroker's Avatar
Im in the same boat. Id do the LP like stated than gauges and chip. Me personally I think im going to go with the edge juice with attitude cs same price as regular gauges and chip but digital.
Sent from my dumb phone!
RA113024
Mar 13, 2016 07:42 PM
PeteBug
Jun 11, 2015 12:16 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
cmalson
Nov 29, 2014 12:57 PM
