Best twin turbo setup?
Old Jul 12, 2012 | 12:05 AM
Cumminsbeast's Avatar
Default Best twin turbo setup?
I have an 01 cummins 24 valve...As of right now i have a 95gph fass lift pump, HotRod Vp44, 75hp injectors,Banks Inatake horn, Stock turbo,Edge JWA, Afe stage 2 intake... i found a slightly used BD super b special turbo for sale for 800 bucks. I want to run twins eventually..I was thinking that turbo and a s400 would do the trick. Id upgrade springs, and headstuds.Are fire rings neccesary? should i take the head off to do the head studs? i have mixed feelings on not doing so..if i did take it off id do fire rings. one more question... if i run the 150hp injectors, will i lose a lot of mileage?
Old Jul 12, 2012 | 07:11 AM
RAW's Avatar
RAW
Fire rings are not necessary, if anything o-ring the head.
The head does not need to be removed for studs. Just make sure you change the bolts out for studs one at a time.
I'm still getting decent mileage with my 150's, and my Compound setup. When I tow, I have never reached 1300* EGT.
Old Jul 18, 2012 | 10:56 PM
01quadcab's Avatar
roll studs in one at a time like mentioned. if/when you blow a headgasket then o-ring the head this is all I did 3 years 85psi 683hp held just fine. the 64 not really ideal for a vp compound setup. a 62 or a 60 is better.
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
GreenDieselF
Oct 20, 2014 02:05 PM
