offer on a eaton 5spd out of fleet truck
Old Jul 11, 2012 | 09:54 PM
12vbigfoot's Avatar
Default offer on a eaton 5spd out of fleet truck
hi i was offered an eaton 5spd out of a cintas truck. it has everything there but the trans is a 2wd and my trucks 4x4 auto. how would i go about doing this swap? the guy wants $400 for everything but i would need to convert to 4x4. i can probly talk him to $300 so im intersted in getting rid of the slush box. any body know about these trans? i dont know if this will tell anyone anything about the trans but some numbers that were on it were 19e00 and A14434 i wouldnt be 100% sure the numbers are correct they were hard to read. please give me info on this swap thanks!
Old Jul 13, 2012 | 09:26 AM
12vbigfoot's Avatar
Anyone? dont want to pass it by if its is doable
Old Jul 19, 2012 | 02:05 PM
senotext's Avatar
It could be done but probably not worth your time and money in the end, probably have to change the adapter on the engine make driveshafts and divorce mount your t-case just for starters, just swap an nv4500 in it if you are tired of the auto
Old Jul 19, 2012 | 03:29 PM
cumminstothefloor's Avatar
Like Seno said, you could run a divorced case, which is fairly easy. Try to get your hand on a divorced np208 or even stronger, a np205 out of an old ford (because of the drop side of the differential). Often found in 70's and older heavier duty trucks. Check out craigslist and read up on it. Very common in the off road world to achieve better drive shaft angles with big lifts.
I've done a few so if you have any questions feel free to pm me.
Old Oct 13, 2012 | 05:09 PM
12vbigfoot's Avatar
do you happen to know if this is an overdrive trans? looks just like a fs-4205b but theres not tag on mine to be sure of.
i can get the serial number off of it if that helps
Last edited by 12vbigfoot; Oct 13, 2012 at 05:09 PM. Reason: Automerged Doublepost
Old Oct 17, 2012 | 06:52 AM
comotionman's Avatar
I don't think its overdrive.
Old Oct 17, 2012 | 04:41 PM
12vbigfoot's Avatar
Have any idea what rpms I'd be looking at cruising 70 on the freeway?
If its not an overdrive transmission the 5th gear is 1:1 ratio
Last edited by 12vbigfoot; Oct 17, 2012 at 04:41 PM. Reason: Automerged Doublepost
Old Oct 17, 2012 | 05:42 PM
H.R.D's Avatar
Maybe useful.....
Eaton Fuller 5-SpeedTransmissions
Old Oct 17, 2012 | 06:20 PM
12vbigfoot's Avatar
would a serial number help anyone identify this model?
doublehbar
13
Aug 9, 2015 12:35 AM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
carid
Diesel Bombers Sponsors
Feb 9, 2015 07:12 AM
Oct 14, 2014 08:40 AM
