How to tell where my lift pump is located?
Old Jul 11, 2012 | 08:32 AM
1999stroker's Avatar
Default How to tell where my lift pump is located?
How do I tell where my lift pump is located? My buddy said on the motor itself.Idk. new to cummins thanks.
Sent from my dumb phone!
Old Jul 11, 2012 | 09:13 AM
empty wallet's Avatar
It could be on the block, under and slightly behind fuel filter canister. If you bump the starter you should be able to hear it run.
Old Jul 11, 2012 | 10:42 AM
Yeah I can hear it run the filter canister is on driver side towards firewall buddy said its on same side but towards radiator
Old Jul 12, 2012 | 06:02 AM
kman522's Avatar
Like Empty said, it should then be behind the fuel filter and slightly below that towards the firewall.
Old Jul 12, 2012 | 07:05 AM
RAW's Avatar
RAW
Find it?
Old Jul 12, 2012 | 07:56 AM
Dodgemanstan's Avatar
Just down and towards the rear from the fuel canister. Pretty much right below it...
Old Jul 12, 2012 | 09:34 AM
Ok ill look after work. Want to see if its been replaced or not.
Old Jul 12, 2012 | 05:59 PM
I took a gander and didn't see anything that looked like a LP I saw something that was cylindrical but not that big? So is it in tank.
Old Jul 12, 2012 | 06:05 PM
Old Jul 12, 2012 | 06:56 PM
RAW's Avatar
RAW
If it is block mounted, it may look like a cylinder. There will be a hose in, and a hose out, with 2 wire going to it. If you turn the key on, and bump the starter it will turn the fuel pump on. Leave the key in the run position, and have a listen for a fuel pump in either of the two locations. It will run for about 25 seconds.
