Harder Better Faster Stronger
Old Jul 11, 2012 | 01:29 AM
TheKid760's Avatar
Default Harder Better Faster Stronger
I got killed by the KDP so I've decided to upgrade a bunch of stuff while I'm in there.
I have a bunch of questions and will be posting them as I go.
Here's a list of my planned mods/upgrades, anything I'm unsure of or would like comments I'll put a (?) after it.
- Twins WH1C over S475?
-CAT S475 ?(75/114 comp 6" inlet, 85mm exducer turbine) I already have it, was lying around...
-5" DP back (I have a 4" hx40 turbo mount pacbrake I'd like to throw in if it wouldn't cork my exhaust too much)?
-5x.011 SAC Injectors
- 60lb springs
- 4k gsk
- #7 banks plate
- afc mods
- mack plug
- colt stage3 big stick cam
- mild ported head
- ARP 12mm Studs
- banks twin ram
- 5spd manual, 4.10's, DRW
- DD clutch?
- 1-3/8" input shaft?
- 5th gear nut retainer
- rebuild vacuum pump
- replace all seals/gaskets, whatever I can get to.
I have a long way to go but it'll be a heck of a lot better. I mainly DD my truck, so spirited street driving, want to take it to the 1/8 a couple times just because, and only tow 10k or under a couple times a year or less, but want to retain ability to tow 15-20k and have it easy for my gf to drive (if that'll ever happen :hehe
Any input is appreciated. Pics to follow...
When pulling the cam I heard a "thud" Damn!
My stock injectors were not seating well.
My solution
The CAT turbo
My LUK stock replacement clutch was barley alive after 100k miles/12 years, I think the guy I bought it from towed a bunch.
Old Jul 11, 2012 | 02:11 AM
Cordova2013-12 Valve's Avatar
Could you stick a little more info out here on this thread about that CAT turbo? Gonna be lookin into a new one soon, and I was thinking of doing something along those lines..
Old Jul 11, 2012 | 10:10 AM
TheKid760's Avatar
I'm not 100% sure it's an S400, I was just told that it's a variation of a Garrett GT47.
Old Jul 11, 2012 | 10:46 AM
But either way it's a bigger turbo that the stocker hx35 right? I'm not turbo inclined, haha, learning as I go
Old Jul 11, 2012 | 10:53 AM
TheKid760's Avatar
yes significantly bigger, from what I can tell (I'm prob wrong though ) it is a 75/85/1.32
Old Jul 11, 2012 | 10:57 AM
I'm gonna take this opportunity to ask what each of those numbers stand for if you dont mind schoolin me a little bit on turbos.
Old Jul 11, 2012 | 09:15 PM
TheKid760's Avatar
Confused about turbo specs... some gurus please enlighten me - Dodge Cummins Diesel Forum
Turbocharger Basics - Diesel Engines - Diesel Power Magazine
Turbo Tech Basic | Turbobygarrett
Old Aug 16, 2012 | 11:16 PM
TheKid760's Avatar
Small update, I've been working a ton and haven't got around to working on Sue much.
I found a killer deal on a Colt Stage 4 Cam, it's bigger than the stage 3 I was planning on, but is pretty close to Hamilton's 188/220 cam that they recommended.
Stage 4 Cam Specs:
181/218 .280/.323 107.5 lsa
I got a bunch of parts in from a Cummins employee acquaintance:
Got my HE431VE turbo in, Specs & Pics:
HE431 ->comp 60-85 turbine 76-67
Fixed my Timing Case with help from a friend and his TIG and Mill:
Here's a quick shot of the mild bowl work I had done, not a great pic:
My own exhaust manifold porting, Still in progress in the pics:
Old Aug 16, 2012 | 11:17 PM
TheKid760's Avatar
And in case any one needs valve-train weights or is just curious like I was:
Intake:
Exhaust Valve:
Keepers:
Retainer:
60lb Valve Springs:
And a shout out to Tork Tek for a great tool. a little snug on the 60lb springs but worked great:
Old Aug 17, 2012 | 04:15 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Keep the pics comin man. Nice job so far!
