Questions about 6.7's
Old Jul 11, 2012 | 12:28 AM
jfollowell's Avatar
Default Questions about 6.7's
Looking into buyin a 6.7 not real sure about them. If I get one only mods that will be done is egr/dpf delete with smarty to clear codes, 5" mbrp tbe, fass titanium 150, gauges, CAI and dual disk clutch. Was wondering how this setup would work? I've heard the 6.7 have weak head gaskets. Any feed back would greatly appreciated. Thanks
Old Jul 11, 2012 | 03:39 AM
dodgeram082500's Avatar
That setup will be great but fair warning the power is addictive that's about where I said I'd stop too. Also the reason our heads gaskets are "weaker" is there's more cylinder pressure due to bigger bore and longer stroke and there's less material between the bores. Kind like the difference between a 350 and 383 stroker I'd rather have the 383 just about any day.
Old Jul 11, 2012 | 06:19 AM
jfollowell's Avatar
Thanks for the input. Will it hold or would it be better to go ahead and get studs?
Old Jul 11, 2012 | 06:34 AM
Really this all depends on end user and his driving style ,but it never hurts to be a little too cautous rather than not cautious enough
Old Jul 11, 2012 | 07:12 PM
baddodges's Avatar
I did all of the above to mine and couldn't be happier. The 6.7 is a powerhouse.
Old Jul 13, 2012 | 09:02 AM
Willy Muhr's Avatar
Depending on if you're running the s06 or the smarty jr, and how much power you're pumping to it, the head gasket could hold forever, and could go in 5000 miles, every truck is different, run it and see how it pans out for you, if the head gasket goes, then id say its time to do studs.
Old Jul 16, 2012 | 06:03 AM
coors_man_2005's Avatar
I would do studs before u have probs i have seen them blow with edge only so i would take take as much caution as i could
Old Jul 16, 2012 | 03:45 PM
peters0756's Avatar
That set up will work fine but power upgrades are like tattoos, one is never enough. The studs is a good investment and go with the better ones (arp 624?) it can be a real saver in the long run.
4x4kingx889
5.9L CR Performance
Sep 10, 2015 03:45 AM
Mar 20, 2015 08:20 AM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
