Surging RPM's
Old Jul 9, 2012 | 04:39 PM
lines24v's Avatar
Default Surging RPM's
everyone, The problem im having is that when my truck gets in to overdrive the rpm's start going up and it only goes up 1000 and then comes back down to where it should be and when it does this it feels like it loses power for a second and that is with the cruise on or off... please help, thank you
Old Jul 9, 2012 | 04:43 PM
Farmboy 2.0's Avatar
Is the true rpm changing or just the tach?
Old Jul 9, 2012 | 05:09 PM
lines24v's Avatar
when the tach moves up it feels like it loses power for a second then it goes to normal
Old Jul 9, 2012 | 05:25 PM
Id say the crank sensor is bad. Thats where your tach reads from on your year
Old Jul 9, 2012 | 07:46 PM
empty wallet's Avatar
Converter locking and unlocking is what it sounds like to me.
Old Jul 10, 2012 | 02:58 PM
lines24v's Avatar
Scott would there be check engine be on and empty wallet how hard is that to change and thats what my bro thought it could be until i found a bad vaccum line so i thought it has that cuz my air only comes out the defrost
Old Jul 10, 2012 | 03:11 PM
There should be with a cam or crank sensor. A few other things to check is all the grounds on the truck. If they are not making a good connection they can cause a interference for the pcm causing a hunt or surge. Also reset the apps sensor and maybe invest or build a apps noise isolator.
BD Diesel - 1300030 - Apps Noise Isolator
Dodge Cummins APPS Reset for 1998.5-2002 5.9L Cummins
Old Jul 10, 2012 | 08:42 PM
lines24v's Avatar
Ok thanks and there isn't a check engine light and ill check the grounds out and check in to that other stuff
Old Jul 12, 2012 | 08:12 AM
lines24v's Avatar
The reset worked scott thanks a bunch and im glad i posted that qustion cuz i wouldnt of know how to do that
Old Jul 12, 2012 | 08:59 AM
lunk's Avatar
damn thats good to know
john grossman
10
Jan 12, 2019 08:58 PM
boneheaddoctor
Jan 15, 2016 06:19 PM
MO.CA. Cummins
Apr 7, 2015 05:47 PM
MIKE3822
Nov 4, 2014 07:34 AM
Jclamorgan
5.9L 24V Performance
Sep 27, 2014 09:47 AM
