Fuel Pressure Question
Old Jul 9, 2012 | 02:04 AM
Young bucK's Avatar
Default Fuel Pressure Question
im getting a airdog 150 and i need a fuel pressure gauge, what size do i get? and would the airdog 150 support 125hp injectors?
Old Jul 9, 2012 | 08:32 AM
Anguss's Avatar
AirDog or AirDog2? Stock VP44?
Either way, 150gph should be just fine to support 125's.
Definitely get Gauges! Lift Pump to VP gauge should read between 0-30psi (a select few might argue higher up to 50psi, but you're playing with fire. The AirDog should come preset regardless of which model you got around 15-17psi, but please be sure to check it rather than assuming it's spot-on, as the VP's are very particular about their incoming psi in order to keep working properly).
Also, get a gauge that goes to 30k, reading psi after the VP.
I would highly recommend a low Lift Pump psi indicator, either an alarm or light, via AirDog pre-wired harness or on a gauge (some Programmers have capability), to quickly bring to your attention if the lift pump quits pumping optimally or completely, for an array of reasons like pump motor failure, shorted wiring, filter plug, etc. It's inexpensive security preventing being stranded, or shopping for a bbq VP.
Old Jul 9, 2012 | 07:30 PM
empty wallet's Avatar
How does the connection for that work?
Old Jul 9, 2012 | 07:34 PM
Dodgemanstan's Avatar
Hmmmm that doesn't seem feasible! but I may be wrong....
Old Jul 9, 2012 | 07:42 PM
Yeah I was being sarcastic.........
you need a 30psi gauge, airdog has a port to tap for fuel pressure but on the vp is where I think is best. 150gph pump will support anything you throw at it, on a vp truck anyways.
Old Jul 9, 2012 | 09:18 PM
Anguss's Avatar
Too much Not enough coffee.
Sarcasm = 30psi only, off AirDog or at least before inj pump, and all good. Not 30k, Not after.
Old Jul 10, 2012 | 10:57 AM
Young bucK's Avatar
haha right on thanks guys
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
scottxmorris
Oct 8, 2014 02:14 PM
cummins Pride
Oct 6, 2014 11:28 AM
