Engine sometimes stalls on inclines
Old Jul 8, 2012 | 02:41 PM
NYKRINDFW's Avatar
Default Engine sometimes stalls on inclines
Also, hard to start when sitting on an incline.
5.9 Cummins TD.
Possible reasons?
TY
NY
Old Jul 10, 2012 | 03:41 PM
rotorhead's Avatar
Default stalling on inclines
I had the same problem with mine climbing Vail pass in Colorado and thought fuel filter, but I changed that, same prob, changed lift pump still same problem. On the way home it just died and would not start. ot home set the linkage aside and removed shut off solenoid, took out plunger, reinstalled and it fired up. Found a solenoid on ebay 9.50, same as early VW with bosch pump. Now works perfect. NAPA wanted 90 something for it but I found it on Ebay. Hope this helps
Old Jul 10, 2012 | 03:46 PM
NYKRINDFW's Avatar
Default K
TY Rotorhead.
NY
Old Jul 10, 2012 | 05:14 PM
rotorhead's Avatar
You are most welcome, If you have to drive your rig until your part comes in, you can you still have to use the manual shut off when you stop. I hope this is what it was because I bleed injectors and still would not start, pulled out that plunger which you can run with out. Oh I used a small chisel to unscrew solenoid as could not fit wrench, came out easy and lightly chiseled tight, check for leaks
Old Jul 12, 2012 | 12:55 AM
1stgenblowingsmoke's Avatar
Just take off the rear pump mount takes 2 extra minutes n you can get a wrench on it.
burndiesel
10
Feb 7, 2023 01:15 AM
dy19333
Ford Powerstroke 08-10 6.4L
Feb 4, 2015 01:12 PM
krinderhagen
Jan 15, 2015 12:07 AM
krinderhagen
Dec 31, 2014 07:12 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
