high trans temp
Old Jul 7, 2012 | 09:01 AM
codyawise's Avatar
Default high trans temp
i got a 99 cummins auto and this is my first automatic. im just curious how high of temperatures are close to dangerous because i do a good bit of haulin. i got a banks dynafact gauge ranges from 140-320 i believe. usually while towin its a little under 200.
Old Jul 7, 2012 | 09:10 AM
Oatmealman's Avatar
That sounds normal to me when towing heavy.When I'm grossing around 34-36k I don't see anywhere over 200ish so it sounds normal to me,that's not in my cummins though.
Old Jul 7, 2012 | 09:52 AM
empty wallet's Avatar
Sounds alright to me
Old Jul 7, 2012 | 10:47 AM
RAW's Avatar
RAW
Sounds just fine. Transmission oil is heated by coolant in the heat exchanger, then sent to the cooler up front to cool down a little bit. Seeing as your coolant is 190*, give or take, anything around that temperature is fine. If you start seeing 220* or higher, it's time to be concerned.
john grossman
10
Jan 12, 2019 08:58 PM
Jake9473
Jul 22, 2018 08:19 AM
ctd04x4
Sep 11, 2015 03:50 AM
casper83
23
Jul 27, 2015 01:53 PM
robbyS
Apr 16, 2015 02:22 PM
