Build it yourself Intake?
Old Jul 6, 2012 | 03:55 PM
firstgenfreak93's Avatar
Default Build it yourself Intake?
If i bulid a custom intake for my 91 using a BHAF what size tubing do you suggest for the best balance between too little and too much?
Old Jul 6, 2012 | 09:06 PM
johnnyreb's Avatar
I used a piece of 5" aluminum irrigation pipe and the elbows off my old tubing
Old Jul 7, 2012 | 12:04 PM
JBradley500's Avatar
A normal paper BHAF should have a 4" inlet and so does an intercooled cummins turbo. Might as well just use 4".
Old Jul 7, 2012 | 07:50 PM
paidoff's Avatar
Default DIY intake
I built one and used 4 in. pipe with 2 45 degree bends and a big K&N filter. It looks good but i am going to put a shield/box in sometime. it helped with out box about 1-1 1/2 mpg alone. then i painted it black with plastic spray paint. Long enough to sit down to collect fresh air through head lights.
P.S. Very hard with what pipe i used to get on filter, but with perseverance its on and clamped good and tight!!
Old Jul 7, 2012 | 09:16 PM
johnnyreb's Avatar
amen to the getting the pipe on. The 5" was a b 'otch. Onlt reason I used 5" was because there was a pile of irrigation pipe lying near by. It toke two people and a heat gun to stretch the elbows over the pipe. free is always good.
DODGEARMYGUY
Feb 8, 2015 07:08 PM
jrsavoie
Feb 6, 2015 09:44 PM
jtwthaxj
Diesel Engine Conversions
Jan 14, 2015 06:52 AM
trevmountain
Jan 3, 2015 09:41 PM
Oct 15, 2014 12:30 AM
