warm weather issues
Old Jul 5, 2012 | 06:04 PM
jdchristian3's Avatar
Default warm weather issues
When truck is up to operating temp, overdrive does not work and the alternator only charges 12.3vdc. I change the alternator out with a new (not rebuilt) unit.NO CHANGE. Not worried about charging system!!! I travel 40 miles on the highway to work. No overdrive and 4.10 gears means I am a road hazard and late to work. HELP!!!
This issue started a while ago, but in the beginning, it was only if i let it idle for 15+ minutes. And then after about 2 miles of driving, it would return to normal... Now, it is all the time. If I can get into overdrive, it will work great until I slow down enough for it to drop into third, then im screwed...
Last edited by jdchristian3; Jul 5, 2012 at 06:04 PM. Reason: Automerged Doublepost
Old Jul 6, 2012 | 04:29 PM
airgord's Avatar
Check your crank sensor connections? Is it clean and is the gap correct, .050 checked with a NON ferrous feeler gauge or a matchbook cover folded over. Outside of that I got nuthin'. Good luck!
dwmeehan
Jan 29, 2025 12:13 PM
mhoos
Ford Excursion 99-05 7.3L and 6.0L
Jul 28, 2015 09:31 AM
ronstop
Feb 26, 2015 09:48 AM
Polaris04
Dec 1, 2014 08:27 AM
Oct 3, 2014 11:30 AM
